Results 11 to 17 of 17
20th October 2008, 11:49 PM #11
Re: What is the point of an access point?
21st October 2008, 12:13 AM #12
HP ML110G6 Server:
Intel Xeon X3440 @ 2.53GHz | 16GB DDR3 Mem. | (1)500GB HDD (3)250GB HDDs in Software RAID5 | Windows Server 2012 Standard
Envy 14 Beats:
Intel Core i5 560M @ 2.67GHz (32nm) | 8GB DDR3 Mem. | Crucial M4 120GB SSD | *BrightView* 1366x768 LCD | Windows 8 Enterprise x64
21st October 2008, 11:37 AM #13Notebook Consultant
- Join Date
- Dec 2007
- Posts
- 198
- Rep Power
- 14
http://www.newegg.com/Product/Produc...82E16833129184
is that a good router/ap? or do you have any other recommendations?
21st October 2008, 11:58 AM #14
A AP is used to connect wirelessly. In most cases you want a wireless router to start off with. You can then add a AP or wireless router setup as a AP to extend your coverage. Most AP are multifunction, meaning they support many modes, client, bridge, multi-bridge, repeater. These features are only supported by third party firmware (dd-wrt) on some routers. Meaning MFG do not want these functions, hurts them on sale of other hardware.
Most business use AP if they want to setup a wireless network on their facility. They will set them up so you can roam all over the facility and not need to login every time you move out of range of your current AP. It is so seamless you will not even know you changed AP.Apple MacBook Pro 15", dual boot
Netgear FVS-338 8-port VPN router,
Dlink DGS-1216T GigE switch,
Netgear WNDR3700v2 used as AP
3 Snap4500 NAS units
21st October 2008, 05:15 PM #15
Also, most modems that the ISPs provide are really Modem+Router combos. Some are even Modem+Wireless Router combos.
You can put a second router after the ISPs router, but if you do you probably should set the ISPs router to be in "bridge mode".
21st October 2008, 10:24 PM #16
And if you have fiber to the house, you don't even have a modem.
"Nothing is free but ignorance"
IFL90 15.4" WSXGA+, T7700 4GB RAM, HD 160GB, BT, WiFi, Vista Business, FP.
22nd October 2008, 11:55 AM #17
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Today, 02:21 PM in Gaming (Software and Graphics Cards)
