Quantcast Turn on Wireless Capability?
Results 1 to 10 of 10
  1. #1
    NBR Lead Moderator
    Jul 2005
    Forest moon of Endor
    Default Turn on Wireless Capability?
    Ok, I need some assistance here.
    I have a review laptop with Windows Vista 32. It was working fine on wireless up until this morning when it refused to connect to a different network (except for "Local" access) (the network worked fine on other machines). I did a "Repair" which somehow screwed the wireless, because now every time I go to connect, Vista says it can't find any wireless networks. When I click Diagnose, it says "Turn on wireless capability". However, the WiFi card is already enabled in the BIOS, the device manager, and even in the Network center. The laptop has no fn+Fx key combinations to enable/disable wireless, and no physical switch. I already uninstalled/reinstalled the device with new drivers and it didn't help.
    Any suggestions?
    NotebookReview Writer & Reviewer
    hp EliteBook 8740w 17" DreamColor2 1920x1200, Windows 7 Pro, Core i5-560M, ATI FirePro M7820, 8GB RAM, 120GB Intel 320 SSD, Intel 6300 WLAN
    Notebook Warranty Guide | Computer Optimization Guide | SSD Upgrade Guide: How and Why
  2. #2
    Notebook Prophet
    Nov 2006
    Default Re: Turn on Wireless Capability?
    Are you sure about the switch and FN keys?
  3. #3
    JSUTAONHTERBIRCKINTEHWLAL
    Jun 2008
    Helsinki
    And I assume you have already tried manually connecting to a network, as well as 'manage wireless networks' and move the networks listed up / down the order in which vista attempts to connect?!!!! *Problem' for chaz himself???* talk about the ambulance itself meeting with an accident!
    Dell XPS M1530 | C2D T9500 2.60GHz | 15.4 Widescreen WUXGA (1920x1200) | 4 GB 667 MHz DDR2 SDRAM | 320GB SATA | 256MB NVIDIA GeForce Go 8600M GT | Windows 7 Ultimate
  4. #4
    NBR Lead Moderator
    Jul 2005
    Quote Originally Posted by John B View Post
    Yup. The laptop came with a sheet that explained all the Fn functions, none of them can enable/disable wireless. There are no physical controls on the laptop to do this.
    Quote Originally Posted by fonduekid View Post
    Yes to those as well - there are actually no networks stored on the computer. I tried manually adding one, which did not work.
    Also, there is no antivirus/antispyware software installed.
  5. #5
    Jun 2008
    Helsinki
    Have u tried system restore to some point before this morning, before u started having this issue? *I guess you did!!*
  6. #6
    NBR Lead Moderator
    Jul 2005
    Alrighty, John B found there is actually a wireless control on it, the touch buttons at the top of it. Thanks John.
  7. #7
    Jun 2008
    Helsinki
    Ah good... finallY!!
    Btw, pssstt pssstt, what laptop is it? *if only you had told me this, I would figured it out.. LOL... j/k Chaz.. anyway have fun with your review...
  8. #8
    Notebook Prophet
    Nov 2006
    We would have to kill you...lol
  9. #9
    NBR Lead Moderator
    Jul 2005
    Alienware Area-51 m17x
    Review should be up in about a week.
  10. #10
    Jun 2008
    Helsinki
    Quote Originally Posted by Chaz View Post
    Wow... Great!
    Alienware was my fav when I was hunting for a laptop, but then it was way too expensive for me right now so settled with the wonderful m1530.. Anyways.
    Love your reviews, Chaz.. and I'll be waiting for it Thanks.
