Quantcast Detected 2 unknown Devices on Network.. How to ping them?
Results 1 to 7 of 7
  1. #1
    Banned
    Sep 2007
    Singapore currently
    Default Detected 2 unknown Devices on Network.. How to ping them?
    This is the MAC ID of someone on my network: e9:eb:b3:a6:db:3c
    pinging on the designated address i.e 192.168.1.71 tells Host unreachable.
    now how do i scan for the device based on its MAC ID?
  2. #2
    Lazy as the Day is Long
    Jul 2006
    The SSR of NYC
    Default Re: Detected 2 unknown Devices on Network.. How to ping them?
    Try installing Microsoft's Network Monitor 3.1; as MS states, it's "a a protocol analyzer. It allows you to capture network traffic, view and analyze it."
    That might give you some more information about the unknown devices you've found. In terms of the "host unreachable" message, I would guess that you're getting that message because the system in question has turned off the functionality to accept pings (it's a common security technique to make it harder for hackers to probe networks - it also has some minor offensive uses as well, apparently).
  3. #3
    Notebook Virtuoso
    Mar 2006
    Look at the routers log, it may tell you more info. At the router you can block the user with a simple rule based on MAC address, then see who hollers.
    Apple MacBook Pro 15", dual boot
    Netgear FVS-338 8-port VPN router,
    Dlink DGS-1216T GigE switch,
    Netgear WNDR3700v2 used as AP
    3 Snap4500 NAS units
  4. #4
    Jun 2007
    Easy answer is you can't. If the device is a computer, and it has firewall on, it won't response to your ICMP packet. You can't use Network monitor either because I assume that you router is acting as a switch, and switch doesn't broadcast the packet unless it doesn't have the device on mac address table.
    Don't forget that switch separates broadcast domain unlike hub. You just have to block or shut down that port. Whatever fits you situation.
    Dell Studio XPS 1645
    Core i7 720QM|8GB DDR3-1333MHz|ATI 4670 1GB|15.6" 1080P WLED|Bluetooth 370|Windows 7 Ultimate 64-bit
  5. #5
    Jul 2006
    The SSR of NYC
    Network Monitor will pick up traffic on the LAN between the router and the other device whether or not the router is broadcasting or sending to a specific IP address.
  6. #6
    Jun 2007
    Quote Originally Posted by Shyster1 View Post
    No it won't. You can't possibly capture the traffic between the router either because router separates and stops broadcast. You will see only ARP request, but there is nothing more.
    If you want to capture the packet, you have to mirror the port on the switch or connect the server into a hub.
  7. #7
    Nov 2005
    What are you trying to do? If you want to keep people of your network secure it and enable MAC filtering.
    Quote Originally Posted by Nocturnal310 View Post
    ~Antec 900~
    i7 920 @4.2Ghz|COGAGE HS & AC 12025PWM push/pull|DX58SO|9800GTX+ OC|6GB OCZ CAS7 1600Mhz|4TB HDDs|Toughpower 650CM|Win7 Ult 64
    ~Gateway P-6860FX~
    C2D T8300 @2.4Ghz|lapped & modded heatsink|8800mGTS OC|17" WXGA+|4GB mem|Intel X-25M G2 80|WD Scorpio320|Intel 4965AGN|Bluetooth|Win7 Ult 64|9333 3Dmark06
