Quantcast How to get into router settings??? Help
Results 1 to 5 of 5
  1. #1
    Oct 2007
    Somwhere
    Default How to get into router settings??? Help
    Ok, i need help fast. i had a problem and reset a trendnet TEW-631 router. But it erased all the settngs and i can get into the settings!!!!! 192.168.1.1 puts me to verizon settings (My modem) and it says the ip of the router i think, but if i type it in , it dowsnt work. i tried 192.168.0.1 and 192.168.1.10 but nothing is working.
  2. #2
    Dec 2007
    Default Re: How to get into router settings??? Help
    Open cmd, type 'ipconfig' and look for the default gateway, that's the IP of the router.
    Intel Core2Duo @ 2.4GHz/core (T7700)
    512mb GeForce 8600mGT
    2GB Corsair RAM
    160GB Harddrive
    "Governments never do anything by accident; if government does something you can bet it was carefully planned.”
    (Franklin D. Roosevelt)
  3. #3
    Moderately inquisitive
    Apr 2005
    Swindon, UK
    If you've done a full hardware reset then it should have defaulted to the settings given in the manual.
    The modem shouldn't be confusing the matter, but temporarily unplug it while you try to talk to the router.
    John
  4. #4
    Oct 2007
    Somwhere
    Thank you so much vashts121.
    + 2 rep
    I dont have the manual handy though, so that wouldnt have helped. I thought they were all 192.168.1.1 or .0.1, but this one is 192.168.10.1. thanks though.
    +2rep
  5. #5
    Dec 2007
    No problem, and thanks for the rep.
    2GB Corsair RAM
    160GB Harddrive
