Quantcast How to get a better wifi signal?
Page 1 of 3 123 LastLast
Results 1 to 10 of 29
  1. #1
    Oct 2007
    Default How to get a better wifi signal?
    Anyone have any ideas on how to? I live on campus and sometimes in my dorm the signal drops down to 3 to 2 bars. So I was wondering are there any ways to stop that?
    If it helps I have a broadcom 4321AG 802.11 a/b/g/draft-n WIFI Adapter in a HP laptop. thanks
  2. #2
    Monkeymod
    Jan 2008
    Under a palm tree on the beach
    Default Re: How to get a better wifi signal?
    Get yourself a hawking technology device, they can boost your signal up to the skies
    "Nothing is free but ignorance"
    IFL90 15.4" WSXGA+, T7700 4GB RAM, HD 160GB, BT, WiFi, Vista Business, FP.
  3. #3
    Bog
    Bog is offline
    Losing it...
    May 2006
    Canada
    http://lifehacker.com/software/how-t...der-296367.php
    According to this link, placing metal sheets behind the antennae of your router can bounce the radio waves and essentially "boost" the signal. Still, not everyone reports success with this. Worth a try, though.
    "Earth" Desktop | Asus 21.5" 1920x1080 | C2D E6750 @ 3.0GHz | 4GB RAM | 500GB + 1TB HD | Radeon 6850 | Corsair TX650 | Windows 7 64-bit
    "Mercury" uMBP | 13" LED | C2D P8400 @ 2.4GHz | 6GB RAM | 500GB HD | Mac OS X 10.7
  4. #4
    Feb 2008
    UK
    Quote Originally Posted by johnny89 View Post
    When this happens, do you experience any problems ?
  5. #5
    Monkeymod
    Jan 2008
    That's true, we call that a reflector, but you will change the antenna pattern perhaps for your own benefit but you will punish the other student using the same router. I'm assuming this is the situation at campus, a router for a floor or two, or even for the whole building.
  6. #6
    Oct 2007
    Quote Originally Posted by Icaru506 View Post
    Not really but on occasion I lose the connection completely.
  7. #7
    Super Moderator
    Nov 2007
    The Bay State
    You can try disabling the power saving feature on your wireless adapter, but this may cost several minutes of battery life.
  8. #8
    Notebook Acolyte
    Nov 2007
    Moscow, ID
    width="425" height="344">
    I'm serious. :twitcy:
    Notebooks:
    Vostro 3555 | AMD E2-3000M 1.8Ghz | 4GB RAM | Radeon HD 6380 | 320GB HD | Win 7 | Xubuntu 12.04
    Vostro 1400 | T5470 C2D 1.6Ghz | 2GB RAM | 128MB nVidia GeForce 8400M | 320GB HD | Win XP Pro | Xubuntu 12.04
    Desktop:
    Gigabyte Mobo | PC Power & Cooling 610W | Intel C2Q Q6600 2.4GHz | Radeon HD 4850 512MB | Crucial 4GB | WD Blue 320GB 7200rpm | Acer 23" 1080p | Win 7 Pro
    Tumblr
  9. #9
    Oct 2007
    Quote Originally Posted by pixelot View Post
    hahaha does that actually work or is it a spoof?
  10. #10
    Monkeymod
    Jan 2008
    Not even my dog believes in it
