Quantcast Help! My ethernet network adapter has disappeared
Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Aug 2007
    Default Help! My ethernet network adapter has disappeared
    Yesterday, I turned my notebook on (HP dv6500t) and noticed my internet wasn't connecting (wired connection). So I went and looked at my network adapters and only my wireless one was listed. Then I went and looked in the device manager and noticed that my ethernet nic wasn't listed there either. I Then tested my wireless nic just to make sure it was working properly, which it is. After I tested my wireless nic I booted in to safe mode, and my ethernet nic was working fine. So I rebooted and it vanished again. I tried a system restore a few time with now luck. I also tried reinstalling the drivers for the nic.
    After all that I backed up my files and reinstalled a fresh copy of windows hoping it would fix my problem. No luck, had the same problem only this time it wouldn't even work when I booted into safe mode. At the moment I'm reinstalling windows with my recovery disc, because if I can't fix this I will have to send it in for warranty repair.
    I would like to avoid sending it in for repair, because I have been trying to sell it recently and I have someone thats pretty interested in purchasing it.
    DV6500T CTO
    - Vista Home Premium (64-bit)
    - Core 2 Duo T7700 (2.40 GHz)
    - 4GB DDR2
    - NVIDIA GeForce 8400M GS
    - Fingerprint Reader + Webcam + Microphone
    - Intel PRO/Wireless 4965AGN Network Connection and Bluetooth
    - 200GB 7200RPM SATA Hard Drive
    - LightScribe SuperMulti 8X DVD+/-RW
    - One 6 Cell and One 12 Cell Lithium Ion Batteries
  2. #2
    1 hr late but moving fast
    Apr 2006
    PCB, Florida
    Default Re: Help! My ethernet network adapter has disappeared
    If it works in safe mode, there's nothing wrong with your hardware. When you reinstalled, did you install all of the required drivers and system software?
    If you have a problem, do everyone a huge favor: post the exact error message. Don't abbreviate or paraphrase.
    New to forums? You really should view this video!
    Inspiron e1705: Core 2 Duo T7200, 4GB PC2 5300, ATI Mobility Radeon X1400, Gigabyte GN-WS30N 802.11n mini PCIe wifi, 250GB 7200rpm drive, Windows 7 x64 Ultimate RTM
  3. #3
    Monkeymod
    Jan 2008
    Under a palm tree on the beach
    Quote Originally Posted by wado-ryu View Post
    Don't sell it if it doesn't work. Just do a clean install and it should work. What is your OS?
    "Nothing is free but ignorance"
    IFL90 15.4" WSXGA+, T7700 4GB RAM, HD 160GB, BT, WiFi, Vista Business, FP.
  4. #4
    Apr 2006
    PCB, Florida
    Quote Originally Posted by Wirelessman View Post
    He's already done an install, and it didn't work. Plus, his signature lists his current OS.
  5. #5
    Monkeymod
    Jan 2008
    I have 4 computers but I have just one laptop in my sig.
    I would still do another clean installation, many times it works.
  6. #6
    Wise One
    Nov 2007
    Mars
    what is your ethernet nic make/model??
    did you try downloading the latest drivers just for it w/ another pc and installing them??
    no need to re-install the OS again!!!!!!!
  7. #7
    Monkeymod
    Jan 2008
    He might not have the drivers disc.
  8. #8
    Aug 2007
    Well as I stated above I was trying to reinstall windows with my factory recovery disc when I first posted this thread. Well it turns out that I had one of those faulty recovery disc's that HP sent out awhile back. So after that install failed I reinstalled a fresh copy of windows again. I did the same thing I did the first time I installed the fresh copy. I applied all the driver and such for my computer (I have them saved on a flash drive). Well after one of the restarts when I installed a driver, windows finally recognized the nic again.
    So thanks everyone for the replies, I appreciate your help.
    DV6500T CTO
    - 4GB DDR2
  9. #9
    Aug 2007
    OMG, I just restarted my computer and now the nic has disappeared again. The only thing I did before I restarted the computer was install some updates from windows update (pre sp1), and turn on network descovery and file sharing. I'm downloading sp1 now and I'm going to try reinstalling the driver when it finishes.
    Anymore Ideas on whats causing this.
    Updates that were installed before it happened again:
    1) Update for Windows Vista for x64-based Systems (KB937287)
    2) Update for Microsoft XML Core Services 4.0 Service Pack 2 (KB941833)
    DV6500T CTO
    - 4GB DDR2
  10. #10
    9262 is the best:)
    Dec 2006
    The World is Mine
    If you can format and start again.A friend of mine had this problem with Dell Vostro and it worked in XP,not in Vista.
