Results 1 to 10 of 24
5th May 2008, 10:07 PM #1Notebook Enthusiast
- Join Date
- May 2008
- Location
- Pennsylvania
- Posts
- 13
- Rep Power
- 13
dell wireless 1390 wlan mini card
In the network setup wizard it says that the mini card is disconnected. I have an inspiron e1405 notebook. I set the restore point back to before I tried setting up a home network and I cannot connect to the internet to see if it need drivers updated. The connection won't repair itself either. I don't know what else to try since I can't get on the internet with that notebook. Any ideas?
5th May 2008, 10:48 PM #2
Re: dell wireless 1390 wlan mini card
Ethernet?
(filler)Notebooks:
Vostro 3555 | AMD E2-3000M 1.8Ghz | 4GB RAM | Radeon HD 6380 | 320GB HD | Win 7 | Xubuntu 12.04
Vostro 1400 | T5470 C2D 1.6Ghz | 2GB RAM | 128MB nVidia GeForce 8400M | 320GB HD | Win XP Pro | Xubuntu 12.04
Desktop:
Gigabyte Mobo | PC Power & Cooling 610W | Intel C2Q Q6600 2.4GHz | Radeon HD 4850 512MB | Crucial 4GB | WD Blue 320GB 7200rpm | Acer 23" 1080p | Win 7 Pro
Tumblr
6th May 2008, 08:10 AM #3Notebook Enthusiast
- Join Date
- May 2008
- Location
- Pennsylvania
- Posts
- 13
- Rep Power
- 13
I'm sorry but I'm not sure what you are asking about the Ethernet.
6th May 2008, 03:25 PM #4Notebook Enthusiast
- Join Date
- May 2008
- Location
- Pennsylvania
- Posts
- 13
- Rep Power
- 13
I know what ethernet is but I'm not sure what you mean for my situation.
6th May 2008, 06:29 PM #5
Can you use it to get online?
Notebooks:
Desktop:
Tumblr
6th May 2008, 09:04 PM #6Notebook Enthusiast
- Join Date
- May 2008
- Location
- Pennsylvania
- Posts
- 13
- Rep Power
- 13
No, I can't get it to connect in any way. When I search for wirelss networks it says I need to use the Wireless Zero Configuration service which I did and it still didn't get online-it keeps showing that message. When I troubleshot the mini card it says it is working fine but the Network Wizard says it is disconnected so now I don't know what to do.
6th May 2008, 10:33 PM #7
The ethernet. Can you use the ethernet to establish a connection?
Notebooks:
Desktop:
Tumblr
6th May 2008, 10:55 PM #8
By ethernet pixelot means when you connect your laptop to the router via a cat 5 cable. We are just trying to isolate the issue.
"Nothing is free but ignorance"
IFL90 15.4" WSXGA+, T7700 4GB RAM, HD 160GB, BT, WiFi, Vista Business, FP.
7th May 2008, 03:02 PM #9Notebook Enthusiast
- Join Date
- May 2008
- Location
- Pennsylvania
- Posts
- 13
- Rep Power
- 13
I just connected it to my modem with the ethernet cable and it said it cannot connect. I clicked repair but it still didn't work.
7th May 2008, 03:55 PM #10Notebook Enthusiast
- Join Date
- May 2008
- Location
- Pennsylvania
- Posts
- 13
- Rep Power
- 13
When I run the network setup wizard it says my mini card is disconnected but I have no idea how to fix that or if it can be fixed so the wizard won't finish setup. When I ran the troubleshooter for the mini card-it said it was fine.
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Today, 09:18 AM in Gaming (Software and Graphics Cards)
