Quantcast Router damaged... how to connect without it?
Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Banned
    Sep 2007
    Singapore currently
    Default Router damaged... how to connect without it?
    Hi,
    my router is damaged.. will get a new one after 2 days.
    Can someone tell me how to connect to Internet without the wireless router?
    I have two cables coming out of the wall.
    both a 2 pin --dial-up cables.
    one for Phone & one for internet.
    WOuld appreciate some help
  2. #2
    McLovin
    Jun 2007
    Default Re: Router damaged... how to connect without it?
    Connect them to your laptop.
    What kind of internet do you have?
    Phone: HTC Droid Incredible 2
    Tablet: Thinkpad X41t | PentiumM 1.6Ghz | 1GB RAM | Intel Graphics | Atheros AR5212 | 60GB HDD
    Laptop: Inspiron 1501 | Turion 2.0Ghz | 1GB RAM | Radeon 1150 | Broadcom B4311 | 160GB HDD
    My blog.
    My tumblr.
  3. #3
    Banned
    Sep 2007
    Singapore currently
    Quote Originally Posted by Thomas View Post
    I have the WLAN network.
    All comps connect to the internet via Wireless Router.
    SO the router is dead.
    i am sitting with my laptop next to the Wall from where a Telephone wire comes out which goes inside the Router.
    How to use that wire to connect to the internet?
  4. #4
    Nov 2006
    are you saying the modem is dead or the router?
    "The reasonable man adapts himself to the world: the unreasonable one persists in trying to adapt the world to himself. Therefore all progress depends on the unreasonable man." - George Bernard Shaw
  5. #5
    Banned
    Sep 2007
    Singapore currently
    look...
    The 2Wire Wireless Router is not with me now....
    I wanna connect to the internet ..
    How do i connect to the internet without the Wireless Router?
    There is a Telephone wire coming out of the Wall which is connected to DSL filter.
    So now how do i use that wire to access high speed internet?
  6. #6
    Banned
    Sep 2007
    Singapore currently
    Before:
    Laptop---->Wireless Router-----> Internet
    Now:
    Laptop---->Internet???
  7. #7
    Dec 2007
    United Kingdom
    If it is DSL, the wire coming from the filter (from the telephone socket) that used to be in the wireless ADSL Router (with in built modem) will now have to be plugged into a seperate USB/LAN MODEM.
    Your ISP should have supplied you with a MODEM. If you bought the wireless router modem by yourself then you may have the seperate modem packed away somewhere.
    Unfortunately if the wireless router came free with your ISP, then you cannot access the internet until you get another wireless router with an inbuilt MODEM
    Toshiba X200-219 | HP Pavilion TX2050ea | Samsung NC10 inbuilt HSPA
    Official Toshiba Drivers
  8. #8
    Banned
    Sep 2007
    Singapore currently
    What!!
    i used to think the standard Modem is in-built in most laptops now.
    You mean without the Wireless Router my entire Connection is wasted? i cannot use it without a Router?
  9. #9
    Formerly waterwizard11
    Aug 2007
    On the Edge.
    Quote Originally Posted by nocturnal310 View Post
    Before:
    Now:
    Should be: Laptop --->wireless Router---->modem---->Internet
    (In some cases Router = modem)
    Then
    Laptop--->modem--->internet
  10. #10
    Dec 2007
    United Kingdom
    Quote Originally Posted by Waterwizard11 View Post
    Then
    What he said above.
    Also the 'MODEM' which comes with the ISP is usually fixed settings to connect to their network.
    Wireless Router (in-built Modem) has to be set manually using the settings provided by the ISP.
    Only Wireless Routers for CABLE MODEMS are 'just' Wireless routers with no in-built MODEM as the Cable company provides the CABLE MODEM which cannot be 'store bought'
    And to answer your question; yes you cannot connect to your internet without a modem or an ADSL wireless router. Laptops may still have built-in DIAL-UP modems but not broadband.
Copyright © 2015 vBulletin Solutions, Inc. All rights reserved.
SEO by vBSEO 3.6.1
