Quantcast Using two wireless adapters for twice the bandwidth?
Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Jun 2006
    Hull, UK
    Default Using two wireless adapters for twice the bandwidth?
    Hi guys. Basically im using one wireless card and i get slight signal loss when playing online games. I have a spare usb wireless adapter, could it be possible to link both the adapters together to get twice the bandwidth?
    Zepto Znote 6214W||14" WXGA 1280x768||Geforce Go7600 512MB||1.83 GHz Intel® Core™ Duo T2400||2048MB (2x1024) DDR2 PC5300 - 667MHZ||60GB 7200rpm
    GA-P35C-DS3R||Core 2 Duo E6550 @ 3.15GHz||Scythe Mine Rev B||2GB DDR2 PC2-7200||Sparkle 8800GT + Accelero S1||36GB+150GB 10000rpm Raptors - RAID 0||Seasonic S12 II 500W||Akasa Zen Black Mod
  2. #2
    Jan 2008
    Default Re: Using two wireless adapters for twice the bandwidth?
    Quote Originally Posted by RichBaines View Post
    try bridging the two connections
  3. #3
    NBR Reviewer
    Mar 2006
    UIUC
    I dont think that is how bridging works. Bridging is used for sharing an internet connection.
  4. #4
    I pwn teh n00bs.
    Jul 2006
    Framingham, MA
    That's not how connections work. If they did, then people would purchase 30 wireless cards and have 30 times the bandwidth...
    You're being limited by the distance you are from the router and the bandwidth limit of your ISP. Adding more wireless connections will not magically decrease the distance to your router and increase the bandwidth that your ISP is giving you.
    You want better bandwidth? Then go out and buy a better and faster connection and make sure that you are very close to the wireless router.
    As I walk through the valley of rice I shall fear no turbo, for torque art with me.
  5. #5
    Jan 2008
    That is not always the rule... you can use a bigger better antenna to increase your connection to the router. Some wireless nics now come with 3 antenna on one card (mostly 802.11n stuff).
    With a laptop you are somewhat limited for external antenna though. I have a second nic in my lappy and I will be installing a connection for a external antenna when I get the cable in the mail.
    I dont know of you can use 2 nics together, but I doubt it is impossible.
  6. #6
    Notebook Virtuoso
    Mar 2006
    Want work, MS does not know how to optimize the use usage of 2 connections. MS will always use the 1st connection. Only time you can use 2 is ICS. Now some SMB routers can use 2 broadband connections with the options of load balancing or fallover.
    Apple MacBook Pro 15", dual boot
    Netgear FVS-338 8-port VPN router,
    Dlink DGS-1216T GigE switch,
    Netgear WNDR3700v2 used as AP
    3 Snap4500 NAS units
  7. #7
    Jul 2007
    It's not possible, sadly enough. It'd be awesome to use two in parallel, like ADSL.
  8. #8
    Jun 2006
    Hull, UK
    Quote Originally Posted by adinu View Post
    Im not quite sure you understood what i meant. I probably should have explained my problem more clearly.
    My wireless router is downstairs (the only place where theres a phone line, its almost directly below me). I game on my desktop (has a wireless pci card). The speed of my ISP is fine (often d/l at 800kb/s ).
    When playing cs:s online for example every 30-60 seconds i'll lag. Which is rather annoying as i always get shot! I know its because of the wireless connection because ive run a very very long rj45 cable down to the router and its fine!
    Upon further investigation i downloaded net stumber to see what my signal strength was like. Signal strength was excellent, there was no noise but the signal would disappear for about 1 second every 30-60 seconds. So obviously this is the cause of my lag in cs:s, but im unsure why its doing it. Any idea's?
  9. #9
    Aug 2007
    ideas? don't game on wireless
  10. #10
    Jun 2006
    Hull, UK
    Quote Originally Posted by NotebookYoozer View Post
    thanks for that suggestion (idiot). but its the only option i have. Anyone else?
