Results 1 to 3 of 3
27th September 2007, 05:24 PM #1Notebook Guru
- Join Date
- Jan 2007
- Posts
- 50
- Rep Power
- 16
internet wont work with ethernet cable??
I'm running windows vista and when i plug in the ethernet cable which is hooked up to my schools internet it come up as local only.... when i plug the same cord into my roomates laptop with vista it says local and internet.... how do i get that connection to change from just local to local and internet??? thanks
27th September 2007, 06:37 PM #2
Re: internet wont work with ethernet cable??
Does your friend have DHCP enabled or is he using a static IP address? (to check this, go to start -> control panel -> network and sharing center -> manage network connections -> right-click local area connection -> double-click Internet Protocol TCP/IP v4. If it is set to obtain IP and DNS automatically, he is using DHCP)
Make sure your TCP/IP settings match his.
You may also wish to make sure that each one of you is actually pulling an appropriate IP address, if he IS using DHCP. To check this, go to start and type "CMD" in the search box. Open the command prompt and type in "ipconfig" and strike "enter." Look for the statistics for the "Ethernet Adapter Local Area Connection." You are mainly concerned with the IPv4 address and the Default Gateway. You need to be sure your notebook is pulling the same GATEWAY as your friend's notebook.Orev's guide to Memtest86
Tim Childree
PowerNotebooks.com
Tim@PowerNotebooks.com
Sager, PowerPro, and ASUS Laptop computers
ResellerRatings.com Lifetime Customer Satisfaction Rating = 9.95
27th September 2007, 06:53 PM #3Notebook Guru
- Join Date
- Jan 2007
- Posts
- 50
- Rep Power
- 16
wow, thank you SO much!!!!!!!1
Similar Threads
Compaq V.6000's Wireless Internet Wont work
By laziboy9 in forum Networking and WirelessReplies: 2Last Post: 24th September 2007, 09:26 PM -
Ethernet Cable Question
By Izint in forum Networking and WirelessReplies: 6Last Post: 19th September 2007, 12:29 AM -
Help! Dell Inspiron 5100 Power Cable Burnout. New cable, wont turn on! :(
By tommyturner2007 in forum DellReplies: 2Last Post: 31st August 2007, 11:08 AM -
ethernet cable
By lordmail in forum Networking and WirelessReplies: 7Last Post: 14th June 2007, 02:16 PM -
which ethernet cable to get?
By fanfan in forum Networking and WirelessReplies: 5Last Post: 2nd December 2005, 10:57 AM
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Yesterday, 02:21 PM in Gaming (Software and Graphics Cards)
