Results 1 to 9 of 9
Thread: Wireless driver issue.
20th June 2007, 06:50 PM #1Newbie
- Join Date
- Jun 2007
- Posts
- 4
- Rep Power
- 0
Hello,
I recently purchased an Acer Aspire 9410. It came loaded with Vista, so I downloaded the drivers from Acer's site and reformatted with XP Pro. All the drivers seem to be working except my 802.11 wireless. Device Manager says there is an unknown wireless device.
Took the panel off the back and it's a Broadcom BCM4311 KFBG. I searched everywhere but cannot find a driver. Can anyone help me out? Thank you in advance.
Regards,
AspireXP
20th June 2007, 07:32 PM #2Newbie
- Join Date
- Jun 2007
- Posts
- 4
- Rep Power
- 0
Re: Wireless driver issue.
Here is my reply from Acer:
Dear XXXX,
Thank you for contacting Acer America. Acer can provide support for the computer as it ships from the factory. If you run a non-OEM version of Windows, please note Acer can provide limited support for non-OEM operating systems as we do not test retail versions of Windows on our products. All drivers and applications that are available for download are on our acerpanam.com website. As some drivers or vital driver links are integrated into the operating system, Acer cannot provide them separately and you may have some loss of functionality. I'm sorry but I am unable to assist you further with this issue.
Regards,
Acer Online Support Team
So I wonder if I'm out of luck...
20th June 2007, 09:53 PM #3Notebook Deity
- Join Date
- Jun 2007
- Location
- New Hyde Park, NY
- Posts
- 1,015
- Rep Power
- 19
here you go brother, assuming what you typed in regarding the model is correct, this is what you need. you can also just go directly to www.broadcom.com and download them there.
http://www.x-drivers.com/component/o...einfo/id,9957/
21st June 2007, 01:35 AM #4Newbie
- Join Date
- Jun 2007
- Posts
- 4
- Rep Power
- 0
Hey PD, thanks for the help, unfortunately the driver didn't work. I'm very confused, it said right on the chip "broadcom bcm4311". The wireless worked with Acer's "special vista". Must be some sort of special driver only available from Acer. Guess the only thing to do is send it back and get their Vista installed, which doesn't seem like something I should have to do.
21st June 2007, 03:20 AM #5Notebook Deity
- Join Date
- Jun 2006
- Location
- Courtenay
- Posts
- 1,690
- Rep Power
- 23
ftp://ftp.work.acer-euro.com/noteboo...3.100.46.0.zip
did you try them
?New Aspire one Sub Notebook
New Ibm X61T 776295U
Sold Acer Aspire 5672
21st June 2007, 09:10 AM #6
Did you load the chip set driver or are you just using MS generic?
Apple MacBook Pro 15", dual boot
Netgear FVS-338 8-port VPN router,
Dlink DGS-1216T GigE switch,
Netgear WNDR3700v2 used as AP
3 Snap4500 NAS units
21st June 2007, 12:35 PM #7Notebook Deity
- Join Date
- Jun 2007
- Location
- New Hyde Park, NY
- Posts
- 1,015
- Rep Power
- 19
21st June 2007, 04:37 PM #8Newbie
- Join Date
- Jun 2007
- Posts
- 4
- Rep Power
- 0
Hello again, thanks for all your help.
Andy - Yeah I tried the one from their Euro site as well.
Blue/PD - I downloaded all the drivers from Acer's site so I'm pretty sure it's installed, but when I get home I'm going to reinstall the chipset drivers, maybe that's my problem.
I'm sure I went wrong somewhere along the line. If all else fails I will format again and see what happens.
21st June 2007, 09:59 PM #9
The chip set should be the first driver installed.
Similar Threads
installing windows xp wireless driver (not intel wireless)
By bunta in forum AsusReplies: 2Last Post: 19th January 2007, 04:07 AM -
Please Help - Driver Issue!!
By L33TAY in forum AcerReplies: 6Last Post: 16th December 2006, 04:06 PM -
driver issue!
By knlmwq in forum DellReplies: 9Last Post: 19th September 2006, 04:37 PM -
Nvidia 7900 GS Driver issue
By citric in forum Hardware Components and Aftermarket UpgradesReplies: 1Last Post: 16th July 2006, 03:39 PM -
Omega driver issue
By heovang85 in forum Gaming (Software and Graphics Cards)Replies: 4Last Post: 12th December 2005, 10:34 AM
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Today, 02:52 AM in Gaming (Software and Graphics Cards)
