Quantcast HP dv6 Battery problem.
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Jul 2011
    underground
    Default HP dv6 Battery problem.
    Hi there,
    I have a HP dv6-2155tx Laptop which is 2010 Model. I have been facing battery problem with it recently.
    The laptop shuts down when it shows 20% or 30% of battery. This means the indicator is wrong ? after a month with this problem. The battery showed me with a red X mark that i have to replace battery.
    I bought a brand new factory sealed battery pack and installed it and had it charged for 3 hours. Battery Status at 99%. It was fine for couple of days and again it started to show wrong status i guess. It shuts down the laptop at 10%.
    Please don't tell me to check the power plan settings. Because i set to hibernate the PC only when it reach 3% So there is no possible reason to take control and put the pc to shutdown. And its a direct shutdown, that just turns off suddenly.
    My laptop specs :
    core i3 2.2Ghz
    4GB
    1GB nvidia 320m
    500GB
    15.6 TFT
    6-cell battery.
    *not in warranty right now*
    Hope you guys can help me out on this issue, Thanks.
  2. #2
    Jun 2011
    Default Re: HP dv6 Battery problem.
    deceptron - have you tried doing the battery diagnostics in support assistant? if so, what is the error number you get?
  3. #3
    Jun 2008
    try battery recaliberation
    Acer Aspire V3-571G:Intel i7 3632QM, Nvidia730m(4g.),16g. ram,1TB.HDD.,15.6"(IPS FHD)
    Dell Inspiron 1525:Intel T4200, 2g.ram,160g. HDD
    Acer Extensa 5220 (Sold): intel T7250, 3g. ram, 120g. HDD, 15.4"
    Past (Sold): hp dv6:Intel i7 2630qm, Ati 6770m (1G.),8g.ram, 1 TB. HDD, Blue ray, 15.6"(HD )
    Past (Sold): hp dv5: Intel T5800, Nvidia m9600GT(512 mb.), 4g. ram, 250 g. HDD.,15.4"
    past (dead) : dell inspiron 6400: Intel T7200, Ati x1400, 2g. ram, 120 g. HDD.,15.4"
  4. #4
    Jul 2011
    underground
    in boot it says
    Primary (internal) Battery (601) error.
    and as per your battery diagonostics in support assistant it says:
    Just replace your battery because it has detected a failure.
  5. #5
    Jul 2011
    underground
    Any help, please ?
  6. #6
    May 2010
    Hello, I'm not sure if this could help. This should help on reconfiguring the sensors to read the correct info from the battery. As I had a problem with my old dv4 laptop that it was reading the wrong battery info and this is what a rep told me when I chatted on HP.com. But Not sure if this will fix your problem. Might be worth a try.
    Step 1:
    1. Remove the adapter and the battery from the notebook.
    2. Press and keep holding the power button for 2 minutes.
    3. Connect the adapter and the battery.
    Step 2: Download and install the updated BIOS
    Step 3: Power management re-installation in windows 7 operating system:
    1) Click on start and type device manager in search field.
    2) Click on device manager in the list.
    3) Click + next to system devices.
    4) Right click on following controllers and select un install one by one. Uninstall only the options that are available in the notebook from the following options.
    a) ACPI Fan
    b) ACPI Fixed feature button
    c) ACPI Thermal Zone
    d) ACPI compliant system
    Restart your notebook after uninstalling all above controllers from device manager. Operating system will install new drivers automatically on restarting notebook.
    Step 4: Completely drain the battery and then again recharge fully before you use it.
    | i7-2630QM | 6GB DDR3 | FHD 1920x1080 | ATI 6770m 1GB | 750GB 5.4k HDD | Blu-ray| Ralink 802.11 a/b/g/n 2x2 | 9-cell Battery | dv6t-6100
    DV6T 1080P Anti-Glare Display, DV6T 1080P Anti-Glare Display 2, DV6t 6100 CTO QE Manuals Reil's Touchpad
    HP DV6T Display Replacement Most stable 6770m Driver?
    Use: site:forum.notebookreview.com and what you want to search on google.
  7. #7
    Jul 2011
    underground
    Thanks buddy, I will give this a try and update you.
  8. #8
    Apr 2011
    You could also check to see if Windows is telling it to shut down too early. On Windows 7:
    Open Control Panel
    (In Category View) click System and Security
    Click Change Battery Settings
    Find the current power plan and click Change plan settings
    click Change advanced power settings
    go down to Batter and expand the category
    expand Critical battery level; if it's at like 30%, change it to about 10%
    expand Low battery action and Low battery level. Set the action to "Do nothing" and the level to 15-20%
  9. #9
    May 2010
    Quote Originally Posted by deceptron View Post
    WHere you able to fix the battery problem????
  10. #10
    Jun 2009
    Bucharest, Romania
    He probably did, by buying a new battery. That's pretty much the only solution.
    DV5-1120eh: Athlon X2 2GHz, 2GB DDR2, HD3470 512MB, 160GB, Atheros wifi, BT, IDT HD Audio, 15.4" WXGA, 8-cell, blah blah. Windows 7 Ult x64
    DV9000 (9750ed): Turion X2 2GHz, 2GB DDR2, 8400GS 256MB OC, 250GB, Broadcom wifi, BT, Conexant HD Audio, 17" WSXGA, 12-cell. Windows 7 Ult x64 ...and it was $300!!!
    Remap your QuickPlay buttons!
SEO by vBSEO 3.6.1
