Results 1 to 6 of 6
6th June 2011, 08:50 AM #1Newbie
- Join Date
- Jun 2011
- Posts
- 2
- Rep Power
- 0
DV6-6 series problems with tearing + other problems
I have a Core i5 -2410 processor and Radeon 6770M graphics card. I've been playing Assassins Creed 1 and 2 lately and both have been tearing up quite badly. I've tried turning V sync on the game and from Catalyst but to no avail. Is there any fix from AMD?
Also sometimes when I'm playing videos or listening to music, it kinda skips a beat for a second every now and then. I know the files are alright so what would be the problem?
6th June 2011, 08:52 AM #2Notebook Evangelist
- Join Date
- May 2011
- Posts
- 455
- Rep Power
- 6
Re: DV6-6 series problems with tearing + other problems
Some people that updated their graphics drivers to the 11.5b hotfix corrected their tearing issues. Give it a shot.
Keep in mind, this 11.5b driver is not switchable graphics supported, you may or may not lose switchable graphics capability (there have been reports of it working fine, and other reports of it not working after this update).
AMD Catalyst? 11.5b hotfix
6th June 2011, 09:17 AM #3
Thats a known issue with the actual game.....it also happens on the xbox 360 and ps3 versions
Assassin's Creed 2 full of screen... | PlayStation® Community Forums
Assassin's Creed has the most tearing I've ever seen, what's going on? - Xbox 360 & Xbox Forums
Assassins Creed screen tearing problem?!? - GameSpot Forums - PC & Mac Games
As for the skipping...dunno, I dont have that issue at all.
Also to install the 11.5a/b 11.6 betas etc make sure you install the original factory driver first, then without uninstalling it install the 11.5's over the top of that.... reason being is that original factory driver comes with the switchable graphics subset(Intel HD SG), and without you will have heaps of issues etcLast edited by lokiswarrior; 6th June 2011 at 09:18 AM. Reason: spelling correction
HP DV6 6027TX
Intel i7 2720QM, Radeon HD 6770M 1Gb, 8Gb 1333MHz DDR3 (Kingston), Crucial RealSSD C300 256Gb, Blu-ray ±R/RW with SuperMulti DVD±R/RW with Double Layer Support, Razer Mamba Gaming Mouse & Coolermaster Notebook Cooler
Kingston HyperX DDR31866 Inbound......
6th June 2011, 01:03 PM #4Newbie
- Join Date
- Jun 2011
- Posts
- 2
- Rep Power
- 0
6th June 2011, 06:07 PM #5
Thats ok dude.Basically the Radeon drivers that your HP shipped with, are the 'Factory' or 'Default' drivers.
You want to download and install the 11.5b hotfix drivers(they contain the 11.5b driver+hotfix). You can get it from here AMD Catalyst 11.5b Hotfix driver download from Guru3D.com
This will give you the latest driver from AMD, may help with your stutter or tearing issue etc. And by install over the top of the factory driver means is this. Traditionally you would uninstall an old driver before installing a new one, however in this case just install it and DONT uninstall the old one. Done
Whats the exact model of your dv6 btw? Can you manually switch between ur Radeon and your Intel or is it done automatically for you?HP DV6 6027TX
6th June 2011, 10:05 PM #6Notebook Enthusiast
- Join Date
- May 2011
- Posts
- 34
- Rep Power
- 5
ya, major tearing problems in crysis 2 and in videos in general. installed 11.5b but nothing changed. I probably just did something wrong...
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Today, 06:42 AM in Gaming (Software and Graphics Cards)
