Quantcast PROBLEM with presario v2710us battery
Results 1 to 8 of 8
  1. #1
    Jan 2007
    Default PROBLEM with presario v2710us battery
    I bought a compaq presario v2710us and the battery only lasts for about 48 minutes with only web browsing. Is this normal? I thinks its a 6 cell battery. Thanks
  2. #2
    ZaZ
    ZaZ is online now
    Super Model
    Jun 2004
    L'Étoile du Nord
    Default Re: PROBLEM with presario v2710us battery
    If it's new then it is not normal.
  3. #3
    Banned
    Feb 2006
    How long have you had the laptop for?
  4. #4
    Oct 2005
    DC
    Has it always been like that? Have you disabled CPU throttling? (Power Options, should be to portable/laptop)
    "The effect of liberty to individuals is, that they may do what they please; we ought to see what it will please them to do, before we risk congratulations."
    Edmund Burke
    L2000 LiveStrong
  5. #5
    Jan 2007
    I bought this laptop new from compusa in early august 2006. It has always been like this since it was new. My laptop also doesnt display the remaining time of the battery life it only displays the percentage.
  6. #6
    Hall Monitor
    May 2006
    You may have received a dud, or the cells were already aged when you got them. You should contact HP and ask for a new battery.
    Assuming they give you one, make sure to follow a few simple care and maintenance tips as outlined in the battery guide.
    As far as the battery % remaining vs. battery time left, that's generally different from system to system. Sometimes there will be a BIOS upgrade that will allow for the switch you're looking for.
    COMPAL HEL80 (PowerPro L 8:15)
    WSXGA+ l Go 7600 l T2500 l AS5 l 2 GB l 100GB 7,200 RPM l Bluetooth
    Finding the Right Notebook l Notebook Battery Guide
  7. #7
    Jan 2007
    its been 5 months since I got the laptop. Can I still replace the battery for free?
  8. #8
    Notebook Nobel Laureate
    Dec 2004
    Charleston, WV
    Quote Originally Posted by LT21 View Post
    It should be covered under warranty for a year.
    Lenovo Thinkpad T400 Intel Core 2 Duo T9400, ATi HD3470/Intel GMA X4500, 160GB Intel 320 SSD/320GB Fujitsu MHZ2320BH G2 5400rpm HDD, 4GB DDR3 1066, 14.1" WXGA+ CCFL, Windows 8 Pro x64
    HP Pavilion DM1-3000 AMD E350, AMD HD6310, 320GB Seagate Momentus 7200rpm HDD, 3GB DDR3 1066, 11.6" WXGA LED, Mint 14
