Quantcast Simple Solution to CAPS LOCK problem.
Results 1 to 2 of 2
  1. #1
    Aug 2006
    Default Simple Solution to CAPS LOCK problem.
    I've had this happen 5 times to me since i've gotten my laptop. It happens when your caps light is on and you're typing in lowercase and then your clicking becomes an issue.
    It was very frustrating and I did all kinds of buttom combinations in an attempt to "rescramble" it back to normality. Finally after 20 minutes of frustration, I solved this problem. I simply held down the right shift button (under enter) and pressed caps lock and it appeared to sync the keyboard again. Worked 5 out of 5 for me. I wouldn't of posted it if it was just pure luck, but trying it and being successful 5 out of 5 I felt I had to share to see if it would work for anybody else.
    HP Customized dv5000t:
    • Intel Core Duo T2500 - 2.0 ghz
    • NVIDIA GeForce Go 7400
    • 100GB 5400RPM HDD
    • 1GB RAM
    • Intel PRO/Wireless 3945ABG Network w/Bluetooth
    • Lightscribe 8X DVD+/-RW DL
    Arrived: 9/5/'06 and loving every minute of it.
  2. #2
    Aug 2006
    Default Re: Simple Solution to CAPS LOCK problem.
    This is the most common issue in dv5000 and dv8000 models. I had the same problem and I removed Synaptics Touchpad driver and have my scroll lock on and the problem never occured to me again.
    You can find more information here:
    DV8000 Series - Keyboard problems. Anyone else?
    HP Pavilion DV5191EA
    Intel Core Duo T2500 (2 GHz)
    2 Gigs RAM (533 MHz)
    NVIDIA GeForce Go 7400 (256 MB)
    15.4" BrightView
    DVDRW with LightScribe
    100 GB SATA (5400)
SEO by vBSEO 3.6.1
