Results 1 to 7 of 7
30th August 2006, 12:34 PM #1Notebook Consultant
- Join Date
- Jul 2006
- Posts
- 101
- Rep Power
- 17
HP Mobile Remote Control vs. HP Mobile Remote Control Express Card
HP Mobile Remote Control Express Card vs HP Mobile Remote Control
- Does anyone know what the difference between the two are? Do you have a link of any pictures of both? Im trying to order a customized dv2000t and both these remotes are among the option. whats the diff? thanks
30th August 2006, 12:43 PM #2
Re: HP Mobile Remote Control vs. HP Mobile Remote Control Express Card
I believe the express card remote is for XP Media Center (which is a new option on the dv2000t).
30th August 2006, 01:02 PM #3
HP Mobile Remote Control = for use with HP notebooks that have PCMCIA Slots.
HP Mobile Remote Control Express Card = for use with HP notebooks that PCMCIA Express Card Slot.
Here's a picture of the two I have, one from my dv1000 with the PCMCIA Slot, and the other from my dv2000 with the PCMCIA Express Card Slot:
I recommend the HP Mobile Remote Control Express Card, since your dv2000 will probably have the PCMCIA Express Card Slot, like mine, and several friend's dv2000's have.
Hope this is helpful.
Vice President, Major Multinational Banking Corporation
"Be fearful when others are greedy, and be greedy when others are fearful." - Warren Buffett.
30th August 2006, 04:07 PM #4Newbie
- Join Date
- Aug 2006
- Posts
- 2
- Rep Power
- 0
this has to have been a mistake on hps part. the dv2000 doesn't have a pcmcia slot! only the new express slot! why would they ever offer a pcmcia remote for a laptop that doesn't have one!
30th August 2006, 04:56 PM #5Notebook Consultant
- Join Date
- Jun 2006
- Posts
- 180
- Rep Power
- 17
They don't. ExpressCard remote is the only one offered for dv2000, PC card is offered for dv1000 series.
Originally Posted by xxnopiratesxx
30th August 2006, 08:48 PM #6Notebook Consultant
- Join Date
- Jul 2006
- Posts
- 101
- Rep Power
- 17
Both remotes are being offered for the DV2000t CTO. Thanks for the answers above, now i know that i should just get the EXPRESS CARD. =)
31st August 2006, 01:19 AM #7Notebook Consultant
- Join Date
- Mar 2006
- Posts
- 125
- Rep Power
- 18
Hi joms,
The Express Card Remote is pretty cool. It controls lots of program functions also. You will have to play with it to find out what it will and what it won't do.HP dv 5030us
15.4 Briteview
100gig, 1 gig
Ati Xpress 200
Lightscribe
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Yesterday, 02:21 PM in Gaming (Software and Graphics Cards)
