Results 1 to 3 of 3
Thread: Power Consumption is not good!
8th August 2012, 06:36 AM #1Newbie
- Join Date
- Aug 2012
- Posts
- 2
- Rep Power
- 0
In the Hp notebook, most of the time battery backup is very poor especially HP pavilion series, we need an alternate for power consumption, while compare to others its too low
8th August 2012, 05:26 PM #2
Re: Power Consumption is not good!
Would I be correct in saying that you're not that happy with the typical battery life of your HP laptop? Which model... that would help. Have you changed power profile and tweaked to set everything to maximum battery life? Set the max cpu to 5%? (Not bad when using a system with a dual core cpu). You can also tweak the services or the applications that start at startup. Please remember that battery life is based on what's running and once you add additional softwware you can't exactly put 'all' the blame of the machine. It will work and use the battery.
P.s. If you 'really' want the maximum battery life then maybe consider the Probook or Elitebook range along with the CC09 and BB09 battery. We're talking WAY over 16 hours of battery life. Weighs quite a bit though
19th October 2012, 02:02 PM #3Newbie
- Join Date
- Aug 2012
- Posts
- 2
- Rep Power
- 0
yep, sounds like a great idea but the thing is most of time CPU consumes 5% of power, it doesn't make any poor performance for battery, i think the additional apps consumes more power thats only the reason may be! perhaps the notebook producer should be aware all of the defects, power consumption is a vital part in notebook, so you guys are did something innovative.
Similar Threads
Fast & low-power-consumption SSD
By strahc in forum Solid State Drives (SSDs) and Flash StorageReplies: 6Last Post: 20th March 2012, 08:11 PM -
Enable ASPM in T61 running Windows for saving ~2W of power consumption
By tqbinh in forum Hardware Components and Aftermarket UpgradesReplies: 5Last Post: 14th September 2011, 06:08 AM -
Linux is not good at power management. True or False?
By The Fire Snake in forum Linux Compatibility and SoftwareReplies: 19Last Post: 9th August 2009, 06:18 PM -
Sony FW Ati 3650m, is it that bad?
By ajdude101 in forum SonyReplies: 15Last Post: 10th February 2009, 11:22 PM -
News Bits: Dell Confirms AMD PCs, $100 Laptop in Thailand, Merom Power Consumption
By Chaz in forum Notebook News and ReviewsReplies: 30Last Post: 21st August 2006, 02:48 PM
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Today, 07:02 PM in Gaming (Software and Graphics Cards)
