Quantcast how to fix the keyboard stuck problem?
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Jul 2006
    Default how to fix the keyboard stuck problem?
    i still havent find a way to fix~~~ help me please
    the ctrl key some time will auto stuck~ ~ i use dv5000 and my computer made in china
  2. #2
    Notebook Virtuoso
    Mar 2004
    Ann Arbor, MI
    Default Re: how to fix the keyboard stuck problem?
    FWIW, my stuck keys problem has diminished over time. Maybe the keyboards just need to be broken in? Not that I'm excusing HP for not getting it right the first time, laptop keyboards no longer being bleeding edge technology and all.
    You're probably best off following the massive stuck keys thread. The dv8000 series has the same problem, if not worse.
  3. #3
    Jul 2006
    so sorry , i cant understand your sentence , please give me a little tip~
    what is "being bleeding edge technology and all"
    what is "best off following"
    thanks to much
  4. #4
    Jul 2006
    Well, not to be mean, but if you are going to contribute to an English language thread, you might as well learn English first.
  5. #5
    Notebook Virtuoso
    Mar 2004
    Ann Arbor, MI
    "being bleeding edge technology and all": I was making a sarcastic comment about HP's failure to make a correctly working keyboard.
    "best off following": the stuck keys thread I linked to is the most appropriate place to get answers for your questions.
    szabodabo: I suspect we should all go back to using Latin as the universal language, though I'd miss tormenting foreigners with English .
  6. #6
    May 2006
    West Covina, CA
    Regardless the keyboard sucks, my shift, ctrl, and the left arrow keys sometimes get stuck. Meaning once its pressed, it stays down. Piece of crap machine, and HP support doesn't give a rats about you. Lesson learned= never buy from hp again.
  7. #7
    Jul 2006
    im chinese speaker~ i cant understand latin language too
  8. #8
    Senior Member
    Feb 2006
    Inside Your HD!
    Alienware M17xR3
    Core i7 2720qm | ATI Mobility Radeon 6990M | Hyperx 16GB DDR3 1600mhz | 1920x1080 WLED | Crucial m4 128GB | 320GB HDD 7200RPM | Bigfoot Killer Wireless-N | Win 7 Ultimate
    Gaming Acessories
    Das Pro Keyboard Silent | Logitech G9x | Steelseries Qck Mass Mouse Pad
    Terran Starcraft 2 Player!
    NBR Marketplace Qohelet's Feedback Thread
  9. #9
    Jul 2006
    thanks too much~ but i was disassembly that more than five times~ but it still had this problem~~
  10. #10
    Jun 2006
    Try using a USB mouse instead of the touchpad. Since I have used an external mouse I haven't had a single problem.
    HP dv5020ca
    AMD Turion 64 ML-32 @ 1.8ghz
    1024mb 333mhz RAM
    80gb 4200rpm
    Dual Layer DVD+/-RW
    ATI Radeon Xpress 200m
SEO by vBSEO 3.6.1
