Quantcast help required using nlite to slipstream
Results 1 to 9 of 9
  1. #1
    Apr 2006
    Default help required using nlite to slipstream
    hi all,
    I'm trying to slipstream my hp 5000t SATA driver in windows xp pro, it worked perfectly but its failing in continuing windows installation with different errors like "can't format drive" and on start of copying it says "Setup was unable to verify drive C: you may not have enough memory or CD contains corrupted files". I'm doing following:
    1) Locating windows source
    2) Task Selection - Selecting All
    3) Integrated Drivers - Insert ->Single Driver->iaahci.inf->Intel 82801FBM SATA AHCI Controller (Mobile ICH6M)
    4) Compatibility - None selected
    5) Remove Components - None selected
    6) UnAttended Mode - Default Hide and Oem PreInstall - selected
    Rest are default, i didnt touched those
    so kindly tell me wats wrong, thanks
    regards
    faraz
  2. #2
    Notebook Virtuoso
    Mar 2004
    Ann Arbor, MI
    Default Re: help required using nlite to slipstream
    I prefer to do driver integration the hard way:
    http://unattended.msfn.org/unattended.xp/view/web/36/
    Also read the companion section on integrating regular drivers:
    http://unattended.msfn.org/unattended.xp/view/web/35/
    If you want to have apps and such install on first boot:
    http://unattended.msfn.org/unattended.xp/view/web/31/
    I highly recommend RyanVM's integrator and post-SP2 update pack:
    http://ryanvm.net/msfn/
    I generally do the bulk of my integration work with RyanVM's stuff and manually and then finish up with nLite for final tweaks and to build the DVD image.
  3. #3
    May 2006
    Kingdom far far away
    Do you do this before using nlite or after nlite has customized your installer?
    thanks
  4. #4
    Apr 2006
    well really i dont understand the process u'v refered me like in the hard way of integration i dont know where is $OEM$\$1\DRIVERS\ path plus in "si3112.sys = 1,,,,,,3_,4,1" does i'v to change just the sys file in it or the rite side as well
    I'v heard from guys here that using nlite is straight forward to slipstream driver my first target is to get windows installed on my notebook, then i'll play with other stuff, kindly tell me the way i'm doing nlite is correct or not, or wat i'v understand from hard way that i can slipstream sata driver without using nlite, i thnk its better but i dont understand it fully. i'm gona attach my oem file for ur reference, so kindly if u can create that section for me which i can include in my text.sif file plus if u can explain me the steps, btw i'v copied the windows files from original windows cd to my hard drive and this is where i'm doing all this.
    kind regards
    faraz
    Attached Files Attached Files
  5. #5
    May 2006
    slip streaming anything other than SATA drivers are eas with nlite. You just basicly just need the .inf files. Some other .inf files might require additional files. But SATA drivers is really a tricky one....
    I don't know but this looks promising:
    1. Copy all the contents of your SATA floppy drivers into a folder on your hard drive.
    2. during "Integrate Drivers" select insert > multiple driver folder.
    3. select the folder you saved the contents of your SATA drivers.
    4. there might be another screen where it will want you to select a SATA model from a list.
    I haven't personally tried it. But it sounds like it should work....
  6. #6
    Apr 2006
    thanks for the reply it seems that rest of steps i did for nlite was correct except this single driver selection, ok i'll try with multiple driver this time..
    regards
    faraz
  7. #7
    Notebook Virtuoso
    Mar 2004
    Ann Arbor, MI
    Quote Originally Posted by NumLock
    thanks
    Before. nLite is the last thing you run.
  8. #8
    Apr 2006
    well it didnt worked for me again.. and during installation it gave error while formating that files are corrupt etc.. i already spent 2 days on it, so i didnt had any other option other then to use the USB Flopy drive... anyway thanks
  9. #9
    May 2006
    Quote Originally Posted by farazfastian
    oh sorry to hear that. btw this might help:
    http://www.notebookforums.com/showth...90#post2187990
