Quantcast Volume button sound - How to turn down?
Results 1 to 7 of 7
  1. #1
    Oct 2009
    Default Volume button sound - How to turn down?
    Hello. Is there any way to turn down the tick tick sound that the volume drag button makes?
  2. #2
    Aug 2009
    Indiana
    Default Re: Volume button sound - How to turn down?
    Yes, go into the bios and disable it
    Apple Macbook Pro 15" 2010
    Intel Core i5 2.4 Ghz| 8GB DDR3 | NVIDIA GT 330M | Intel X-25 M 160GB | Still as AWESOME as Day 1
  3. #3
    Banned
    Jun 2009
    United Kingdom
    Don't listen to him , he's talking rubbish.. just go and uninstall the Hp quicktouch drivers... they seem to be the ones making the sounds..
  4. #4
    Aug 2009
    Indiana
    Quote Originally Posted by sean473 View Post
    OK first off, unistalling quicktouch would also work but disabling it in the bios will not remove the software designed for the buttons. ITs better to disable the noise in the bios.
  5. #5
    Jun 2009
    Bucharest, Romania
    Quote Originally Posted by mattmjb0188 View Post
    Seconded. Why such an option would be put in the BIOS, hell knows, but that's the way it is, and it works.
    DV5-1120eh: Athlon X2 2GHz, 2GB DDR2, HD3470 512MB, 160GB, Atheros wifi, BT, IDT HD Audio, 15.4" WXGA, 8-cell, blah blah. Windows 7 Ult x64
    DV9000 (9750ed): Turion X2 2GHz, 2GB DDR2, 8400GS 256MB OC, 250GB, Broadcom wifi, BT, Conexant HD Audio, 17" WSXGA, 12-cell. Windows 7 Ult x64 ...and it was $300!!!
    Remap your QuickPlay buttons!
  6. #6
    Notebook Virtuoso
    Jul 2009
    Jacksonville, Florida
    Clicking on the volume icon in the tray and muting HP MediaSmart in the mixer works fine for me.
  7. #7
    Oct 2009
    Thank you all. In the end i have found a way that just show how the idiots that made HP software are incompetents or evil. After using the quick launch buttons just for luck i clicked in "open volume mixer" and a "Quick Launch Volume" appeared in it , besides the usual "speakers" and "system sounds". I turned down the volume and that was it. Btw the "Quick Launch Volume" just disapeared and i can't find a way to call it . So i don't know the sequence that made it appear.
    Edit: i don't have any HP mediasmart in the Volume Mixer.
SEO by vBSEO 3.6.1
