Quantcast Fan always on (BIOS) and loud noisy fan problem on HP Pavilion dv5, dv7 etc. SOLVED!
Results 1 to 8 of 8
  1. #1
    Jan 2009
    Default Fan always on (BIOS) and loud noisy fan problem on HP Pavilion SOLVED!
    Here is the solution: http://notebookequus.blogspot.com
  2. #2
    Jul 2008
    Default Re: Fan always on (BIOS) and loud noisy fan problem on HP Pavilion dv5, dv7 etc. SOLVED!
    Thank you for this very detailed explanation!
    But, will it work with the dv4t???
    I hope the HP BIOS development team puts more effort on their BIOS updates!!!
  3. #3
    Jan 2009
    Quote Originally Posted by PlanetEarth View Post
    Yeah, i think it will work on almost all HP notebooks, old and new. For example, in the article mentioned in my explanation, the author patched the fan speeds on the HP Compaq nc8430 laptop, and in comments, another user with the HP Compaq 6730s have also successfully patched his laptop. And maybe it will even work on non-HP notebooks, because all laptops have the DSDT tables in their Windows registry.
  4. #4
    Jul 2008
    Hi Thanks for the tutorial. (the fan on my dv5z with the athlon x2 ql-60 cpu was driving me insane).
    I made the changes to the ASL file as you suggested, but when It's time to load the file, I get an error saying that the registry path does not exist. Do you know what might be wrong? Thanks!
    c:\ACPI>asl /loadtable -v dsdt.aml
    Microsoft ACPI Source Language Assembler Version 3.0.1NT [Aug 29 2006, 14:17:49]
    Copyright (c) 1996,2006 Microsoft Corporation
    Compliant with the ACPI 3.0a Specification
    DSDT info for update image (dsdt.aml)
    Size of image: 38476
    OEM id.......: HP
    OEM Table id.: 30F2
    OEM revision.: f0000000
    Error: Count not access the registry path: System\CurrentControlSet\Services\ACP
    I\Parameters\DSDT\HP____\30F2____\f0000000
    c:\ACPI> dir
    Volume in drive C has no label.
    Volume Serial Number is CEB3-BB17
    Directory of c:\ACPI
    01/29/2009 07:50 AM .
    01/29/2009 07:50 AM ..
    11/03/2006 12:54 PM 184,168 asl.exe
    01/29/2009 08:00 AM 38,476 dsdt.aml
    01/29/2009 07:57 AM 287,858 dsdt.ASL
    01/29/2009 07:47 AM 38,480 dsdtorig.aml
    09/29/2008 10:37 PM 11,264 equus.exe
    5 File(s) 560,246 bytes
    2 Dir(s) 27,109,937,152 bytes free
    c:\ACPI>
  5. #5
    Jul 2008
    nevermind... the problem was that I did not run cmd as an admin. the loading works now.
  6. #6
    Jan 2009
    Quote Originally Posted by extra_credit View Post
    So, have you liked the new DSDT settings? What fan speed values have you used, like in my example or some other?
  7. #7
    Jul 2008
    i used your settings, and i still get the same noise all the time. i suspect it's because my laptop uses the Athlon x2 64 ql-60 chip, which is a desktop chip , and does not have any power mgmt features. when doing firefox work, the amd overdrive utilty reports 54-57 deg. C. I'm going to give it one more try with the fan at 10%
  8. #8
    Jul 2008
    this last config here gives some noise, I guess i'll have to get used to the noise.
    Name(BCLT, Package(0xd)
    0x64,
    0x13,
    0x0,
    0x0,
    0x0,
    0x0,
    0x0,
    0x0,
    0x0,
    0x0,
    0x0,
    0x13,
    0x64
    i broke down and ordered a fanless inspiron mini 12 . i can use my dv5z only when necessary. I should have just gotten a macbook from the beginning .
