Quantcast dv5t color display problems & sleep problem
Results 1 to 10 of 10
  1. #1
    Sep 2008
    Default dv5t color display problems & sleep problem
    I'm having a couple of problems with my new dv5t (with infinity brightview 1680x1050 display).
    1. Colors are way off. Working on a project in photoshop on this computer, the colors are far more desaturated than on other computers. Makes big problems with printing.
    2. When I close the lid and it goes to sleep, very often when I open it back up it won't comeback, all the lights are on on the dashboard, but the screen is blank black and no matter what I press it won't come back-- so I end up having to hard shutdown.
    Any ideas?
  2. #2
    Sep 2008
    Default Re: dv5t color display problems & sleep problem
    bumppppppp
  3. #3
    Oct 2007
    1. You'll need to use a monitor calibrator like a Spyder3... the software will analyze and create a colour profile for your screen...
    2. I've had that happen to me a few times on my DV7... no idea what's causing it...
  4. #4
    Jul 2008
    I hope the Nvidia defects didn't make it onto the DV7.
  5. #5
    Sep 2008
    Quote Originally Posted by cpu2k View Post
    Spyder3 costs 450 bucks! Any less expensive alternatives?
  6. #6
    Sep 2008
    Arlington, TX
    Quote Originally Posted by ethos View Post
    Bittorrent?
    HP HDX16
    Intel core 2 Duo (2.8ghz)
    Full 1080p Display
    Nvidia 9600m GT
    4gb Memory
    320gb Hdd @ 5400 rpm
    Light Scribe super-multi drive
  7. #7
    Oct 2007
    Yeah... there's a Spyder2Express... it's should be significantly cheaper than the Spyder3 and should get the job done...
  8. #8
    Sep 2008
    I was thinking along the lines of hopefully something free :O
  9. #9
    Sep 2008
    Still having this problem, any fixes that don't cost so much money?
  10. #10
    Oct 2008
    There is, manual calibration I think. This thread discusses it. Hope that helps.
    HP tm2t: Core i3 @ 1.3 - Intel HD - 500GiB 7.2kRPM - 4GiB - 12.1 @ 1280x800 Wacom Pen & Touch
    HP dv5t (1G): C2D @ 2 - Intel 4.5k MHD - 320GiB 5.4kRPM - 4GiB - 15.4 @ 1680x1050 Infinity
    OS: Windows 8
    Prev: Gateway CX210X
    Mobile: Nokia Lumia 900 Tango 8779
