Quantcast hp dv2000 volume problem
Results 1 to 4 of 4
  1. #1
    Jun 2008
    Default hp dv2000 volume problem
    hi, i just got a hp dv2000 2 days ago and i just found out that whenever i'm online and use those volume buttons at the top right my laptop seems to freeze for awile with the volume display on. the more i press the longer it freezes. like maybe say i want to up the volume 4 times, i click on it 4 times and it usually freezes with the volume display for like at least 1 min. has anyone with the same laptop had the same thing happen? is it normal? or anything i can do to fix this?
  2. #2
    Jun 2008
    Default Re: hp dv2000 volume problem
    btw the model is dv2845se
  3. #3
    Dec 2006
    San Jose, CA USA
    I think you will find the answer to your issue here:
    QuickTouch locking up when Office/Internet Explorer running
    HP Pavillion dv6775us
    Intel C2D T5450 1.66 GHz||4GB DDR2 PC6400||Nvidia 8400M GS 256MB||Hitachi Travelstar 7K500 500GB 7200RPM||Intel 4965AGN||Windows 7 x64 PRO
  4. #4
    Jul 2008
    Hey, dude, I have the same laptop, dv2000, I bought mine from BB about 2weeks ago, and Im getting the same problem, some times the problem just comes up without me even touching the volume control, its really bad when Im on youtube and decide to adjust the volume using the touch bar, then Im stuck with the volume thingy in front of me, this thing is really getting annoying, besides this I love the laptop so far
Copyright © 2015 vBulletin Solutions, Inc. All rights reserved.
SEO by vBSEO 3.6.1
