Quantcast Question : about my Dv6790 ej / cooling problems
Results 1 to 8 of 8
  1. #1
    May 2008
    Default Question : about my Dv6790 ej / cooling problems
    hi i have dv6790 ej Hp
    and i have Question
    does it ok when , i play havey games
    on max graphics
    my heat that coming out of laptop is CRAZY!!!
    the color of my laptop near the cpu and gpu air ways is little gray 0\_o
    cuz of the heat
    what should i do ?
    and is it should be like that ?
  2. #2
    Notebook Virtuoso
    Sep 2006
    PA-US
    Default Re: Question : about my Dv6790 ej / cooling problems
    Run Hardware Monitor and show us some temps http://www.cpuid.com/hwmonitor.php
  3. #3
    May 2008
    wow my gpu 61 C!!! idle
    wwhen i played it was hoter!! omg
    HDD 45 C
    proccerors 45 C idle
    omg?????????????
    i am playing now gpu over 70 C!!!!!!!!!!!!!!
    and Cpu 70C+++
  4. #4
    Notebook Virtuoso
    Sep 2006
    PA-US
    The cpu and hdd look normal, but I'm not sure about the idle temp of 61C on the 8400M GS (as my Go 7200 idles around 50C). Perhaps someone with the same gpu can post their idle temp......
    EDIT: What is your current BIOS version? F.51 updates the fan algorithms so the unit runs cooler.....
  5. #5
    May 2008
    my bios is f.53 the latest one i did update from hp site
  6. #6
    Moderately Indeterminate
    Aug 2007
    Sydney
    Your temps are still in the usual range.
    You can improve your temps by getting a cooling pad and/or undervolt
    #flickr - flipfire
    [Desktop] Silverstone LC20B | Q8200 2.8ghz | GTX680OCE | 8GB RAM | 128GB M4 SSD | 12TB HDD | Intel 6300N |
    [Notebook] HP DV2500 Verve SE | T7500 | 8400GS | 4GB DDR2 RAM | WD 250GB HDD | Intel 4965AGN |
    [Worktop] NZXT Apollo | i7-3770 | GTX 460SE | 12GB DDR3 | 120GB Intel 330 SSD | M-Audio Delta 66 |
  7. #7
    May 2008
    what u mean under volt?
    is there any fixed bios for hp dv6000?
    better then f.53?
    aor tweaked one ?
  8. #8
    Aug 2007
    Sydney
    No there are no third-party BIOS's As far as I know. If you have the latest one, then thats it.
    Read the undervolting guide in my sig for more info
    #flickr - flipfire
