Quantcast Possible to reactive/rejuvenate the battery?
Results 1 to 3 of 3
  1. #1
    Sep 2006
    Default Possible to reactive/rejuvenate the battery?
    My battery, after almost one year's use, reports about 82% capacity. Is there any handy tools out there to reactivate the battery?
    I remember Thinkpad has a tool to fill the capacity. Hope Hp can have one.
    All big corporations screw you, though differently.
  2. #2
    Jul 2007
    Default Re: Possible to reactive/rejuvenate the battery?
    i think it naturally deteriorates over time.
  3. #3
    May 2005
    I does deteriorate over time due to wear, but you can re-calibrate the battery from time to time. HP has a guide to do this on their website somewhere. Essentially, what it is, is for one disable any power saver options that might be there and run the laptop till it shuts down (not a windows shutdown but it just turns off due to lack of sufficient battery power) and then charge it back up to 100%. This apparently re-calibrates it.
    Apple MacBook Pro
Similar Threads
  1. Replies: 8
    Last Post: 17th May 2007, 10:25 PM
  2. Replies: 5
    Last Post: 2nd January 2007, 12:42 AM
  3. Replies: 1
    Last Post: 28th December 2006, 03:59 AM
  4. Replies: 6
    Last Post: 22nd December 2006, 02:02 PM
SEO by vBSEO 3.6.1
