Quantcast laptop not starting up power light blink
Results 1 to 7 of 7
  1. #1
    Jun 2007
    Default laptop not starting up power light blink
    i having hp dv5237cl when try to start this up its power light blink and nothing comes on screen .i have no clue what happen can anyone tell what is possible wrong with my laptop thanks
  2. #2
    Band of Gypsys
    Sep 2006
    Massachusetts, US
    Default Re: laptop not starting up power light blink
    Is the battery dead?
  3. #3
    Notebook Virtuoso
    Dec 2006
    reseat the RAM, or take it out and insert the stick/s again. if that doesnt work take one out and see if that helps, if not then take the other out and put the first one back in.
    is the laptop plugged in and receiving power? battery ok?
    did something happen before? like a system crash? u dropped it or banged it while moving it around? system got really hot? tried to upgrade BIOS?
  4. #4
    Jan 2005
    Pittsburgh, PA
    Try the following remove the battery and then press the power on button, it help release and electricity left then place the batter back . and Power it on. If the lights just blink then.........press and hold the battery button for force a shut down then power it back on. I have this happen when the battery was low and it went into a stanby mode and couldn't come out of it due to low battery and this helped.
    Proud Leader Of The " Geek Squad"
  5. #5
    NBR Super Moderator
    Jul 2006
    NBR Moderator HQ
    Remove both the AC adapter and the battery when you are doing to that stuff as previously posted.
    Desktop   15" Macbook Pro Retina
    W7 Ultimate, Core i7 4770k, Crucial M500 240GB SSD
    16GB RAM, GTX 780, 3x Dell U2412M Surround
       Mavericks, Core i7 4750HQ, 8GB RAM
       256GB SSD, 32GB iPad Air
  6. #6
    Jun 2007
    the battery and power are perfectly fine .
    i try to boot from the bootable cd still nothing is having ..
    Can you please tell me how to upgrade BIOS
  7. #7
    Notebook Virtuoso
    Dec 2006
    u cant if ur laptop doesnt start. like i asked before did something happen recently that might affect it? did u try reseating the RAM? if nothing works then its busted, take it back for repairs.
Similar Threads
  1. Aspire 5633 - lights blink, won't boot
    By ma701ss in forum Acer
    Last Post: 13th June 2008, 04:39 PM
  2. does anyone w3j blink?
    By dorkiedoode in forum Asus
    Last Post: 30th January 2007, 11:49 PM
  3. TM 8204: Blinking Power Light
    By orthorim in forum Acer
    Last Post: 27th December 2006, 07:39 PM
  4. Replies: 3
    Last Post: 10th September 2006, 08:52 PM
  5. Help with thin and light, battery and power!
    By pedrodd in forum What Notebook Should I Buy?
    Last Post: 2nd August 2006, 06:10 PM
Copyright © 2015 vBulletin Solutions, Inc. All rights reserved.
SEO by vBSEO 3.6.1
