Quantcast Power Adapter - hot hot hot!
Results 1 to 10 of 10
  1. #1
    Jan 2007
    Default Power Adapter - hot hot hot!
    Does anyone else's brick portion of their power adapter get hot? I mean - i'm almost scared to leave it on my sofa cushion while I use my laptop. It's pretty hot to the touch.
    I'd leave it on the ground if I could but the length of the cord is too short. I'm just seeing if this is normal.
  2. #2
    Mar 2005
    Default Re: Power Adapter - hot hot hot!
    I noticed mine gets hot when the battery is low and is in the charging stage.
  3. #3
    Apr 2006
    I dont live, right now i am existing
    mine gets hot, but not tooooooo hot, its just like "warm"......but for your question, i would rather not put it on the sofa (fire hazard)
    MSI GT70-2PC DOMINATOR--> Intel Core i7 4810MQ (2.8GHz) | nVidia GTX870m 3GB GDDR5 | 8GB DDR3 RAM | 1TB HDD | Windows 8.1 64-bit
    OLD BEAST:
    Sager NP5793
    Intel Core 2 Duo T8300 2.4GHz / 3MB L2 Cache| 4GB DDR2 667 |nVidia GeForce 9800M GTS 512MB GDDR3 |320GB 7200RPM Hard Drive|Windows Vista Ultimate 64-bit
  4. #4
    Oct 2005
    DC
    Every once in a while, somebody checks his/her adaptor and finds out its hot...Don't worry it's absolutely normal. The temp of the adaptor depends on the supplied electricity, the ambient temperature, the amount of power the laptop draws, etc. There's also difference if you are in Europe, USA or Australia (different standards of power characteristics)
    "The effect of liberty to individuals is, that they may do what they please; we ought to see what it will please them to do, before we risk congratulations."
    Edmund Burke
    L2000 LiveStrong
  5. #5
    Nov 2006
    I have a dv8000 and dv9000 both bricks get so hot I cannot touch them and also am afraid of the fire hazard. Hp says its normal. I say its ridiculous. One is a 65watt (dv8000), the other is a 90watt (dv9000), and in charging mode both get that hot. What model do you have?
    Sami.
    Hp Hdx9130el Intel core 2 duo, T7500 (2,2 Ghz) 20.1" WSXGA+, ATI Mobility Radeon HD 2600 XT, 256MB GDDR3, 320 GB (2 x 160GB) SATA 5400 rpm, 4Gb DDR2 667MHz, Dvb-T Analoge/Digital Hp Tv Tuner, Light-Scribe DVDRW 802.11 pre-n WLAN and Bluetooth.
  6. #6
    Mar 2008
    I take a heatsink from an old motherboad or CPU and attach it to the "brick" with an elastic. This keeps the "brick" a bit cooler. : )
  7. #7
    Jan 2008
    Quote Originally Posted by oakenshea View Post
    lol, are you serious?
  8. #8
    May 2007
    I have a small wood box i use to prop the brick up so it does not make the carpet so hot!... this is for my c500 though... don't know why it gets that hot... the computer seems to get very hot to... to the point i have to take it off my legs!
    I would like you to take a moment to go to my web site.
    It has been totally redone and moved to a new server so
    now I have complete control of what is going on!
    www.brendynj.axspace.com
  9. #9
    Moderately Boss
    Aug 2007
    Sydney
    I sit my brick below my laptop cooler but yes it does get quite hot
    . #flickr
    [Desktop] Silverstone LC20B | Q8200 2.8ghz | GTX680OCE | 8GB RAM | 128GB M4 SSD | 12TB HDD | Intel 6300N | Dell U3014
    [Notebook] HP DV2500 Verve SE | T7500 | 8400GS | 4GB DDR2 RAM | WD 250GB HDD | Intel 4965AGN |
    [Worktop] NZXT Apollo | i7-3770 | GTX 460SE | 12GB DDR3 | 120GB Intel 330 SSD | M-Audio Delta 66 | Dell U2913
  10. #10
    Feb 2008
    New York
    Mine gets oooooooober hot - like hotter than Jessica Alba naked hot. Like, can only put my finger on it for 10 seconds hot. Like, I use it to fry my eggs in the morning hot.
    Okay - it's pretty hot, but only when charging the battery.
    "When all else fails, Google it."
    HP Pavilion DV2740SE 14.1" Entertainment Laptop (AMD Turion 64 X 2 Dual Core TL-62 Processor, 3 GB RAM, 250 GB Hard Drive, Nvidia GeForce Go 7150M, Vista Premium)
SEO by vBSEO 3.6.1
