Quantcast Grinding noise coming from the DVD drive
Results 1 to 7 of 7
  1. #1
    Jun 2013
    Default Grinding noise coming from the DVD drive
    Hello,
    today I bought a used Dell Latitude E6400. As I installed the operating system I noticed that the DVD drive is really loud. I made a video of it: Noise of the DVD drive of my Dell Latitude E6400
    I checked if the disc is properly inserted and it is. Question is now whether the drive is defective or it has something to do with the case above the drive. Maybe something above it is loose. How can I check for the source? I don't want to replace a still functional drive. The casing above the drive is not yielding too much. It feels pretty solid. I can only press it down for 1 mm or something. I does not always sound like that. Only when its under heavy load or when I press the drive into the case or the case above the drive. Watching a DVD for example is okay. Not too much noise.
    Thanks for your help.
  2. #2
    Nov 2011
    Default Re: Grinding noise coming from the DVD drive
    Quote Originally Posted by urbaindepuce View Post
    Hello,
    Does it do this for all dvd media or just that one media? There shouldn't be any noise from the drive itself other then the spinning noise. I heard some dvd I rented do that and if you spin it on the drive spindle by hand you notice that the dvd media itself is kinda warped and that will make the similar noise as well. Did you check to see if there wasn't any foreign debris in the drive itself as well? If you can would be to pop out the drive itself and do a physical lookover and see what if anything is wrong visually as well. But that drive could've been heavily used before you got it and that could be that it is in need of a replacement drive as well. But from my experience drive shouldn't make that noise if it is in working order. But beyond the spinning noise you hear normally that noise you posted isn't something that should emanating from the drive.
  3. #3
    Jun 2013
    I inserted the discs I used into my other notebook and everything was fine. I did this with 3 discs, so I am pretty sure thats not it. I opened the drive and took a look into it. Everything looks alright. The empty bay also looks normal. The top of the drive is yielding even under light pressure, but I guess thats normal, because of the material used (very thin aluminium I guess).
    So you think I should replace the drive? The case of the Dell Latitude E6400 seems very sturdy. I have my doubts that this is the issue, but I can press the casing above the drive down slightly.
  4. #4
    Nov 2011
    That noise I heard on youtube was a little excessive noise for a drive. If the disc works and spin fine in the other players I would if you can get another drive if possible and swap out and see if the problem isn't here still. I heard my drives spin a high pitch wine but your grinding noise is more then just a high pitch wine spinning drive though. But if you have a spare around I would try that and swap it out and see if the problem isn't there for a test. That noise sound like something is making contact that shouldn't be contacting that how I perceive it. But if your other drives match the connection give those swap and see what happens. That way we can eliminate the drive as the problem and we can go from there and see if the laptop itself has some kinda obstruction to the drive working properly.
  5. #5
    Just This Side of Senile
    Jan 2009
    Jackson, NJ
    it sounds like the disc inside is slightly out of balance. If the media was designed and balanced for 4x speed but you are running it at 12x speed this could be the issue.
    Samsung NP700G7C-S01US, Windows 7, i7-3820 + 4 Bins, BD R/W, GTX 675m, 16GB Ram, 480GB Mushkin SSD Boot & 750GB 7,200 RPM Data, 400 nit 1080p 120Hz screen.
    Gateway P-79xx, Windows 7 64 Pro SP1, qx9200 @ 2.93-3.20 GHz, 8GB Ram, Mushkin Chronos DX 480GB, 500GB XT, Flush USB 3.0 express card, 260m Desk @ 550/1000/1350, Game @ 600/1000/1450 & powermizer off.
    Asus U81a, P8400, Windows 7 64 HP, 5-5-5-18 Memory (2x2GB), 500GB Momentus XT.
    Stock system, not in my house!!!!
  6. #6
    Jun 2013
    I did not want to risk buying another drive, because I was not sure was the issue. But fortunately I found a store in my city which had one of these to try out. So it turned out the drive was faulty. After a change everything is fine now.
  7. #7
    Nov 2011
    I kinda figure it was that just from the hearing the sound your drive was exhibiting on the video but only way to be sure was to swap the drive out and then you would know what was the problem and where it was coming from.
Similar Threads
  1. Sony CW i3/i5/i7 Official Owners Thread
    By riverman76 in forum Sony Owners' Lounge Forum
    Last Post: 25th February 2014, 08:41 PM
  2. Alienware M15x - Grinding Noise on Start Up (Optical Drive?)
    By annapocalyptica in forum Hardware Components and Aftermarket Upgrades
    Last Post: 28th November 2012, 12:59 AM
  3. Clicking Noise issue *resolved*
    By Cyanize in forum Dell
    Last Post: 16th April 2012, 07:50 PM
  4. hardware problem with DVD player - 6860
    By Rotz in forum Gateway and eMachines
    Last Post: 1st October 2008, 09:53 AM
  5. help, something seriously wrong with my hard drive
    By sarahloggin in forum Hardware Components and Aftermarket Upgrades
    Last Post: 30th May 2006, 12:58 PM
Tags for this Thread
SEO by vBSEO 3.6.1
