Quantcast GPU fan doesn't work
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Nov 2011
    Default GPU fan doesn't work
    A few days ago, something happened to my laptop fan in the GPU. In SpeedFan I could see my GPU was running at 0 RPM, I assume its broken. I've noticed lag when I play my games and today I received a message when I was starting my computer up that my fan had broken and needed repairs. I can no longer hear my fan run as it used to. I am out of warranty both with HP and the store I bought it from, so how much would it cost to get this repaired somewhere? (I could not do this myself).
    HP Pavilion dv6-6153cl
    Intel i7-2630QM (2GHz) | 8GB DDR3 RAM | AMD Radeon HD 6770M (dna drivers) |750GB 5400RPM HDD | 1366x768 | 6-Cell Battery | Steel Gray
  2. #2
    Sanity = √(-x)
    Nov 2010
    Chasing imaginary butterflies into something highly illegal
    Default Re: GPU fan doesn't work
    Fans don't get repaired, they get replaced. There's no point in asking a repair shop. They will just replace the broken fan anyway. If you know what you are doing, you can tear it down and replace the fan yourself. The catch is finding and buying one online. You would need to get a hold of the actual GPU fan in your system to see what part number it is and search Google using that.
    "The question is never why, it is always why not."
    Alienware M17x-R2 Lunar Silver:
    Intel i7-920XM | 1920x1200 LCD |
    AMD Radeon HD 5870M |
    8GB Vengeance PC3-12800 DDR3 RAM |SB Recon3D Omega Wireless |
    Intel Centrino Ultimate-N 6300 |
    BD-ROM/DVD+RW/DL |
    256GB Samsung 840 PRO
    | 2 x 750GB Western Digital Scorpio Black |
    Windows 7 Ultimate x64 | Notepal Cooler Master U3 |
  3. #3
    On the way out
    Feb 2010
    World@WAR
    I have a microcenter close to my home, they charge $70/hour. I can't imagine this would take more than 1 or 2 hours. The part S/B ~ $30
    HP Pavilion DV6-6100 DV6-6000 DV6-6050 DV6-6090 Laptop CPU Fan [HP Pavilion DV6-6100 Fan] - $25.99 : (I am not recommending this site just using it as an example for pricing).
  4. #4
    Nov 2011
    Quote Originally Posted by Ritzy Cat View Post
    Well first off as others mentioned you replace the fan not repair it fans will die and there is no way to fix other then replacement fan. I would say like another here replied you have to take apart your laptop and get to the GPU fan and there should be a sticker with the part number listed on it. Then go to eBay and find that part number for a "New" and buy that and replace it with that one and that should fix the dead GPU fan. But you need to take it apart to be sure it has two fans one for CPU and another for GPU or just a CPU fan.
  5. #5
    Nov 2011
    I do have a MicroCenter near my home, It's where I got this laptop too. Compared to other places would that be the best deal? I'd imagine something like Best Buy would be double the price or something.
  6. #6
    Feb 2011
    Idk, who would charge you least but its usually a fairly simple fix. Use this teardown guide for your laptop and you should be all set.
    Manuals for HP Pavilion dv6-6153cl Entertainment Notebook PC | HP® Support
  7. #7
    Jun 2008
    first of all, this problem is very common in hp pavilion dv6.
    I had the same problem and I fixed myself, I ordered the fan from ebay. it worked fine and match to original fan. (see my posts in hp thread)
    New HP Pavilion dv6 6000 dv6 6050 dv6 6090 dv6 6100 Series CPU Cooling Fan 4 Pin | eBay
    It is easy enough, just fellow service manual and you will be fine and it won't cost you more than few bucks.
    Acer Aspire V3-571G:Intel i7 3632QM, Nvidia730m(4g.),16g. ram,1TB.HDD.,15.6"(IPS FHD)
    Dell Inspiron 1525:Intel T4200, 2g.ram,160g. HDD
    Acer Extensa 5220 (Sold): intel T7250, 3g. ram, 120g. HDD, 15.4"
    Past (Sold): hp dv6:Intel i7 2630qm, Ati 6770m (1G.),8g.ram, 1 TB. HDD, Blue ray, 15.6"(HD )
    Past (Sold): hp dv5: Intel T5800, Nvidia m9600GT(512 mb.), 4g. ram, 250 g. HDD.,15.4"
    past (dead) : dell inspiron 6400: Intel T7200, Ati x1400, 2g. ram, 120 g. HDD.,15.4"
  8. #8
    Nov 2011
    Thank you - I am PRETTY sure it'smy GPU fan for the 6770m that's not working, not the CPU one. Which one should I buy in this case? in SpeedFan it says the GPU fan is running at 0 RPM.
  9. #9
    Jun 2008
    in Hp pavilion dv6, there is only one fan for CPU + GPU as both use same heat sink and one fan.
    SpeedFan can't detect hp fan speed, so you shouldn't rely on it.
    use CPUID Hardware Monitor to detect your CPU+GPU+HDD temperature.
    a simple way to find if your fan works or not, is to check for hot air coming from the air vent at laptop left side, and whether it is speed changes (become louder and more air) with load.
    An easy way to reduce hp pavilion temperature:
    1) use compressed air can to remove any dust blocking air vents (few blows at vents will be enough)
    2) use Hp CoolSense (coolest mode)
    3) raise back of laptop.
  10. #10
    Nov 2011
    I'm pretty sure it's broken, not only by that but by the fact none of my games run as smoothly as they did before.
    Can someone link me or tell me how to find out what exact product I need to get, and how fast it would be to install it & what kind of technical skills I need?
Similar Threads
  1. Fan problem, help!
    By Hefner in forum Sager and Clevo
    Last Post: 21st March 2012, 01:04 AM
  2. My laptop DOESN'T work...
    By underheart in forum Samsung
    Last Post: 3rd July 2010, 04:47 AM
  3. GPU Overheating. Fan doesn`t work in games.
    By nindustrialny in forum Gateway and eMachines
    Last Post: 3rd June 2010, 01:22 PM
  4. 6930G GPU fan problem
    By Hiddenkill in forum Acer
    Last Post: 19th August 2009, 12:49 PM
  5. Notebook GPU shows high temp.!!!
    By Pranalien in forum HP & Compaq
    Last Post: 30th July 2008, 01:31 AM
SEO by vBSEO 3.6.1
