Quantcast Gateway NV55 trouble removing LED bezel screw covers
Results 1 to 3 of 3
  1. #1
    Aug 2012
    Default Gateway NV55 trouble removing LED bezel screw covers
    Hi,
    I am working on a Gateway NV55S15U laptop. I have removed rubber bezel screw covers before with ease. These screw covers seem to be a plastic and I don't want to scratch the heck out of them because they have a gloss finish. Any suggestions for easy removal ? It seems like they might be glued onto the screw.
    Thanks,
    John
  2. #2
    Jul 2011
    Chicago, IL
    Default Re: Gateway NV55 trouble removing LED bezel screw covers
    I worked on an NV55C before and those plastic screw covers will come off with a small flat head screw driver or a small knife.
    Maybe this will help.
    Gateway NV55C Laptop Screen Replacement Procedure - YouTube
    HP ProBook 6475b
    AMD A10-4600M - AMD Radeon HD 7660G - Samsung M471B1G73BH0-YK0 C11 DDR3L-1600 2x8GB RAM - Samsung 830 256GB SSD - Broadcom BCM943228HM4L 802.11a/b/g/n 2x2 WiFi Adapter - Broadcom 20702 Bluetooth 4.0 Adapter - HP DVD A DS8A8SH - HP 720p webcam - AU Optronics B140XW01 V9 1366x768 14" matte display - AKE BC338/BC618T eSATA/Dual-USB3.0 ExpressCard - MS Windows 7 Pro x64 + MS Windows 8 Pro x64
  3. #3
    Aug 2012
    Thanks for the link. The screw covers took some scratches and after removal it looked like they had a good bit of adhesive. Oh well I guess ebay for cosmetics now.
    Thanks again
    John
Tags for this Thread
