Quantcast Asus X53E No LED backlight after screen replacement
Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By wishmasteruk
Thread: Asus X53E No LED backlight after screen replacement
  1. #1
    Jun 2012
    Default Asus X53E No LED backlight after screen replacement
    Hello everyone,
    I've got the same issue as mentioned in this thread Inspiron 1545 LED screen - no backlight? .
    I stupidly replaced the LED screen on an asus laptop with the battery in. I've followed this post and a couple of others and tried to locate the right fuse to solder but I cant seem to locate it anywhere.
    here are some pics of both sides of the board near the screen connector cable.
    http://postimage.org/image/41krn3gp7/
    http://postimage.org/image/dnec3e7uz/
    as you can see there are no F anything markings, nor are there any markings like that anywhere on the board.
    any help would be amazing as I've tried everything I can think of!
  2. #2
    Aug 2012
    Default Re: Asus X53E No LED backlight after screen replacement
    Hello,
    You probs won't see this but it's worth a shot, did you have any luck with this? Someone I know of is having the same issue with an Asus X5EA.
    Best of luck
  3. #3
    Jan 2013
    Quote Originally Posted by mrapter View Post
    Hello everyone,
    View image: IMAG1043
    View image: IMAG1044
    hi mrapter, did you find a solution for your laptop? i have the same moel and exactly the same problem, i hope you solved it and give me some hints please where to find that fuse, thank you
  4. #4
    Feb 2014
    Hello everyone,
    hi just fixed mine today (x53e) after testing just about every part on the board replace the jumper or bridge it like i did good luck
    Click image for larger version.
  5. #5
    Feb 2014
    wishmasteruk thank you so much
    It's was exactly that jumper, i tested it with my continuity tester.
    Soldered it and everything is fine
    Saved me a lot of money
SEO by vBSEO 3.6.1
