Quantcast Memory: 16GB at 1333Mhz or 12GB at 1600Mhz - Page 2
Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 43
  1. #11
    Apr 2011
    Default Re: Memory: 16GB at 1333Mhz or 12GB at 1600Mhz
    Quote Originally Posted by maverick1989 View Post
    Like KCETech said, it depends. You cannot say that 4x4GB at 1333 is better without knowing OPs needs.
    No it doesn't, and yes i can.
    The 4x4GB dual-channel performance increase will completely nullify any performance gains by getting 1600MHZ instead (not to mention most laptops only support up to 1333MHz) and then there's that whole extra 4GB of RAM.
    Quote Originally Posted by HTWingNut View Post
    Ever heard of asynchronous dual channel? It will not be measurably faster. In any case you're splitting hairs in performance for 99.999% of users and applications.
    And you're not? Ironic considering you're arguing a noticeable difference between 1333MHz & 1600MHz.
    Plus, asynchronous dual channel applies to different capacities, you still need the 4 sticks of RAM for it to work. 3x 1600MHz still isn't going to help you there.
    Keep in mind the OP is specifically asking about 3x4GB dimms, not 2x4GB & 2x2GB.
    [ M11x R3 | Core i5 2467M @ 2.3GHz | 8GB 1600MHz DDR3 Hyper-X | 128GB Crucial M4 | 1GB NVIDIA GeForce 540M ]
    [ M11x R1 | Core2Duo SU7300 @ 1.7GHz | 8GB 1333MHz DDR3 | 640GB WD Blue |1GB NVIDIA GeForce 335M ]
    [ G73-JH | Core i7 740QM @ 2.9GHz | 16GB 1600MHz DDR3 | 500GB WD Black + 2x 320GB WD Black | 1GB ATI 5870m ]
  2. #12
    Wisdom listens quietly...
    Aug 2009
    In a new Ivy Bridge based notebook, I had the chance to try 2x4GB 1600MHz RAM vs. 2x8GB 1333MHz RAM and I noticed a huge and immediate performance drop when the (16GB) lower spec'd but higher capacity SoDimms were installed.
    The whole system felt sluggish; IE would take a few seconds to display new webpages and basically the i7 3610QM system responded like something from 2007.
    Putting the 1600MHz (8GB total) RAM back, the system felt once again like the 2012 high performance system it is (even with the ancient 5400RPM HDD the system shipped with).
    My advice: keep saving until you can afford the proper rated RAM for your system (I'm assuming this will be going into an Ivy Bridge system, of course). If we're talking about a Sandy Bridge based system, then I'll agree with most here that the 1333MHz SoDimms (16GB total) will be the superior configuration - unless it's installed in a very highend i7 (XM) SB based system).
    Good luck.
  3. #13
    Apr 2011
    Quote Originally Posted by tilleroftheearth View Post
    Good luck.
    Why would you be assuming this is for an Ivy Bridge system? What has been said where which would give you that indication?
    Also you're comparing 8GB of 1600MHz with 16GB of 1333MHz, it's documented that systems can run slugish if too much memory is installed but unused and I've observed this myself. Not to mention not every chipset or board supports 8GB dimms.
  4. #14
    Aug 2009
    Where have you seen that 'too much memory makes systems run sluggish'? ROTHFLMAO
    By stating my assumptions, I don't have to care what system is being considered: (especially since none are mentioned by the OP at all) - and my observations stand on their own.
  5. #15
    Everything is Awesome!
    Jul 2007
    Kra gl e Factory
    Quote Originally Posted by Rishwin View Post
    No you don't. Asynchronous works with any number of sticks. Since there's only two memory controllers having 8GB (2x4GB) in one channel and 4GB (1x4GB) in the other will still be asynchronous. Asynchronous works with single + dual channel and optimizes for use with RAM amount that is dual channel. So in my example 8GB would be dual channel and the other 4GB single. In Intel systems it's called "Flex Memory". In any case it really doesn't matter much.
    FOR SALE: *NEW* Clevo P377SM 880m SLI $2500 Shipped!
    Latest Reviews: NP7338 W230SS 860m | NP9377 P375SM 880m SLI | NP8268 P150SM-A 880m | other Clevo : Aorus X7 : Other Reviews
    Sager NP7338 'Serenity': 13.3" 1080p IPS Matte - i7-4810MQ - GTX 860m - 16GB 1866 - 256GB Plextor M5M + 960GB M500 - Intel 7260 802.11AC - Win 8.1
    Stuff: Vaio Pro 11 i5/1080p/4GB/128GB, LG G2, Acer V5-122p, WHS 2011, Desktop SFF i5-3570k/670m
  6. #16
    Apr 2011
    Some older controllers run slower when using 8GB dimms, most don't have native support for them. Also from memory the only 1st gen i-series chip which supports 8GB dimms is the i7. 8GB in dimms in general have some compatibility issues and can not simply be used in every system.
  7. #17
    Ura!
    Jan 2011
    Palmetto Cluster
    My vote for OP: get whatever is on sale. Seriously. Assuming that your laptop has a dGPU (in iGPU case, 1600MHz might be better).
    Ignoring iGPU, you won't notice **any** difference between the two choices, other than a 4GB difference. Even then, you probably won't max out 12GB (I've tried everything other than some scientific computing and 4+ VMs, which will max that out). 1333MHz and 1600MHz won't matter to you unless you're benchmarking (basically: "I got bigger numbers than you!! So mine's better!!" in my book).
    Пoлюшкo-пoлe
    Пoлюшкo шиpoкo пoлe
    Eдyт, дa пo пoлю, гepoи
    Пpoшлoгo вpeмeни гepoи...
    Extended Signature
  8. #18
    Jul 2007
    Kra gl e Factory
    8GB is MORE than adequate unless you run lots of VM's or have specialized software that needs tons of RAM. 1333 vs 1600 MHz is minor difference.
  9. #19
    Aug 2009
    I'll repeat again that on an Ivy Bridge based system 1333MHz SoDimms made a new system basically unusable.
    You've been warned...
  10. #20
    Ura!
    Jan 2011
    Palmetto Cluster
    What?
    1333MHz vs 1600MHz for Ivy bridge? - AnandTech Forums
    Пoлюшкo-пoлe
    Пoлюшкo шиpoкo пoлe
    Extended Signature
SEO by vBSEO 3.6.1
