Quantcast Both touchpad buttons right-click
Results 1 to 3 of 3
  1. #1
    Jun 2007
    Default Both touchpad buttons right-click
    For some reason, both the left and right buttons on my brother's Toshiba Satellite u400 right click. I just did a complete format, and it's still the same. Could it be a hardware issue? I've never seen such a thing. I doubt it's software, because I doubt there's even an option to enable both of them to be right-clicks at the same time?
    HP Pavilion DM4 || i5-430m | 6GB DDR3 | 750GB 7200RPM | ATI 5450 ||
    HP w2207h 22in | Klipsch Image S4 | Logitech MX1100 | HP Photosmart All-in-One |
  2. #2
    Wisdom listens quietly...
    Aug 2009
    Default Re: Both touchpad buttons right-click
    Could be software... is the right driver installed? Check to see that all is aligned in those options.
    If hardware related, is a piece of dirt/crumbs pressing both buttons down no matter which button is pressed? Try some compressed air to see if it dislodges quickly?
    If the contacts are simply worn out... time for a replacement touchpad assembly.
  3. #3
    Jun 2007
    I took it to a tech... hopefully he can fix it. Even he said it's very strange...lol.
SEO by vBSEO 3.6.1
