Quantcast Remote control
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Remote control
  1. #1
    Jun 2006
    Default Remote control
    Hello everybody
    I'm in the process of shopping for a new lappy, which is proving rather difficult due do my random requirements. In particular, i want a fully programmable remote control, and a small and sleek looking one at that. The laptops that come with remotes don't fulfil my other requirements, so i have to come up with an aftermarket solution.
    My main question here is: if a lappy i get has an IR port (as does the asus w3j that i'm leaning towards), can i get any remote and somehow program the computer to recognize the signals? Could someone point me in the direction of some good links, as i'm really having a problem googling this?
    I would rather not get a USB or cardbus TV tuner, i have no need for it and don't want to travel with extra items, and i HATE dongles, so using an existing piece of hardware such as an IR port would be ideal.
    Any help would be appreciated!
  2. #2
    Banned
    May 2006
    Bellevue, WA
    Default Re: Remote control
    I'm sure if you could find a program that would allow it then it would work, but I'm not sure if there are any such programs available.
  3. #3
    NBR Super Moderator
    Sep 2005
    London, UK
    I wouldn't recommend using IR as your remote receiver, as you have to actually aim for the port (and the IR port of a laptop is usually at the side or back, making it a bit difficult to receive the signal at times).
    I know that if you have a bluetooth enable mobile phone, you can program it to become a remote control for your PC by using applications such as Bluetooth Remote Control 2.0 http://www.bluetoothshareware.com/bl...te_control.asp
    Notebook - 15" Macbook Pro 2.8Ghz T9600; 512MB nVidia 9600M GT; 4GB DDR3 SDRAM; 256GB Kingston V100 SSD; omg 7 hours battery
    Desktop - Case: Coolermaster Centurion 590; Mobo: ASUS P5QL-E; PSU: Corsair TX650W; CPU: Intel E8500; GPU: Asus GTX480 1536MB; Sound: Creative SB X-Fi; RAM: 2x2GB Corsair TwinX; HD: 500GB Maxtor Diamondmax something; Optic Drive: Pioneer DVR215DBK; Wifi: Some 802.11n card
  4. #4
    Jan 2006
    years ago there was an HP remote control, which most people (including myself) never were able to get properly working.
  5. #5
    Jun 2006
    strikeback03 - do you mean this and this? How close to working did they get?
    budding - the BT remote is a fantastic idea if it works - gonna check it out, but i suspect that my phone - moto v635 is not supported. perhaps time for a new phone to go with a new lappy?
  6. #6
    Jan 2006
    no, much older, it occasionally recognized a button push but usually not - had to press just right.
    My phone uses Verizon's POS bluetooth, so I doubt it is useful as a remote.
  7. #7
    Notebook Nobel Laureate
    Feb 2005
    Toronto, Canada
    Alienware M11x - SU7300 / GT335m / 8gb DDR3 / 60gb Vertex II
  8. #8
    Apr 2006
    My Dell remote works well but, I HATE that the receiver has to be connected to a usb port. I might as well get a wireless mouse..
  9. #9
    Fallen to the Sith...
    Apr 2006
    UK
    Get a Toshiba Qosmio. it comes with a remote that can be used to contol Media centre aswell!! I think Fujitsu laptops also come with a smaller but less functional remote control.
    check them out here:
    Qosmio
    http://laptopmag.com/Review/Toshiba-...-G35-AV600.htm
    Amilo A series laptop:
    http://www.fujitsu-siemens.com/home/...o_a_1667g.html
    Asus A6JC
    Core Duo T2300 - 1GB RAM - 80GB HD - Go 7300 512MB
    3DMark05 - 1529 - Forceware 174.31
  10. #10
    NBR Reviewer
    Jan 2005
    Bangkok
    I use my cell phone to control my PC, all medias n' even desktop. This is done via bluetooth, the cell i'm using is Symbian based.
    "The biggest risk in life, is not taking one"
