Quantcast cpu temps
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: cpu temps
  1. #1
    Feb 2011
    Just left of nowhere, TX
    Default cpu temps
    Hi everyone, been searching the net for info regarding the critical temps of the processor and gfx card in my new laptop without much luck, and was wondering if anyone here could offer any insight.
    cpu is a phenom II n660, gpu is mobility radeon 6650. Temps under load according to hwmonitor are: 75c (cpu) and 72c (gpu). This was after a couple hours of gaming, and running the crysis benchmark. Should i worry about cooling?
  2. #2
    such bacon. wow
    Oct 2010
    Rockville, MD
    Default Re: cpu temps
    What is your ambient room temperature? And notebook manufacturer did you buy it from? If it's HP, then I'm not surprised at all by those temperatures, they always did have a poor cooling system design.
    Sager NP8170 (Gaming DTR): i7-2670QM|16GB DDR3|Radeon 6990M|Crucial M500 240GB SSD|17.3" 1080p|7HP
    Sager W86CU(Backup DTR): i7-720QM|8GB DDR3|GeForce 280M|Samsung PM810 256GB SSD|15.6" 1080p|7HP
    ThinkPad Edge E535(Fiance's): A8-4500M|8GB DDR3|Radeon 7640G|Samsung 840 120GB SSD|15.6" 720p|7Pro
    Latitude E6430 (FDA work laptop) i5-3210M|4GB DDR3|Quadro NVS5200M/HD4000|Scorpio Black 320GB|14.1" 720p|7Enterprise|Lenovo ThinkVision L2251p&D221 WSXGA+
    Other toys: iPhone 5 White|AT&T Blackberry Bold 9900 (work)|2014 Subaru XV Crosstrek Premium CVT|2nd gen Nexus 7 16 GB|Latitude 13 Review|Dual Lenovo X220 Tablet review!
  3. #3
    Mr.Mischief
    Jun 2010
    IDK?
    Those temps aren't bad at all. Actually they're quite good.
    I consider anything under 90C fine.
    2012 MacBook Air 11
    iPhone 5c
  4. #4
    404
    Aug 2009
    That's absolutely fine. I'm surprised by the fact that your GPU is cooler than your CPU, it's usually the other way around. Your GPU temps are even cooler than my repasted G73.
    You only really need to worry when the CPU goes above 85C and the GPU above 90C.
    i7-3930K│Asus P9X79│16GB DDR3 1866Mhz 9-10-9-27│EVGA GTX 680 Superclocked Signature│Crucial M4 128GB│Western Digital Caviar Black 1TB│Silverstone FT02│2x Dell U2711│Windows 7 Ultimate
    Macbook Pro 13│Intel Core i7-2640M│8GB DDR3│Intel HD 3000│Crucial M4 256GB│OS X 10.7
  5. #5
    Jun 2008
    this might help
    NBR Cooling Central
  6. #6
    Feb 2011
    Thanks for the replies. Just a little paranoid i guess, much less worried about it now
    Quote Originally Posted by Tsunade_Hime View Post
    Manufacturer is acer, room temp is around 70*f (21*c)
  7. #7
    such bacon. wow
    Oct 2010
    Rockville, MD
    If your ambient is 21, it is running on the hotter side, but nothing too worrisome. Acer typically has better cooling designs than HP...
  8. #8
    Nov 2007
    Quote Originally Posted by CZX58 Shadow View Post
    what a wrong statement that would be, LOL. When was the last time you touched a laptop GPU working at 90 deg C ?
    what are you all talking about, anything in your laptop that heats up slightly above room temperature is NOT fine. It just shows how much improvement is needed in the laptop area
    but to the OP: those CPU and GPU temps are acceptable. If you can, bring them down though ... as I did with my laptop - when maxed out on both CPU/GPU I get ~65 deg C top, and that's with over 50% overclock on the GPU. I would like them to top out at 30 deg C though ... ehhhhh some day
    T61: 14.1" 1400x1050, T9500 @ 2.8GHz, 4GB RAM CL4, nVidia 140m @ 600/925 MHz, Samsung 830 256GB, DVD-rec, 5300agn, FP, BT, 6-cell, clean XP Pro
    T61: 14.1"w 1280x800, T9500 @ 2.8GHz, 4GB RAM CL4, Intel X3100, Samsung 830 256GB, DVD-rec, 4965agn, 4-cell, clean XP Pro
  9. #9
    Mr.Mischief
    Jun 2010
    IDK?
    Quote Originally Posted by miro_gt View Post
    Do you own a laptop, or any type of computer? I see a laptop in your sig, but I'm doubting. The GPU and CPU in every computer in the world go way over room temp. The outside of a laptop may stay cool, but the internal components always get hot.
    2012 MacBook Air 11
    iPhone 5c
  10. #10
    Nov 2007
    Quote Originally Posted by tHE j0KER View Post
    <- el.engineer
    also, I bet I've been around computers longer than yourself (no disrespect), I still remember my 8088 and what I did with it. Speaking about CPU/GPU temps of every computer in the wold is plain stupid.
    I just said what a laptop temps should be, compared to what they are these days. Heat + electronics = not good
    I was aiming mostly towards the comment about 90 deg C GPU temps as being fine .. where the max allowed is typically around 100
SEO by vBSEO 3.6.1
