Quantcast Help, i7-640m vs i7-820qm
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Nov 2010
    Default Help, i7-640m vs i7-820qm
    Dear guys
    I want to buy new laptop, and finally there are two alternatives. Both of them are local brand.
    1st choice
    i7-820 + gt 335 1 gb
    pros= better proc (?) and gpu
    cons = shorter battery time + more expensive (more USD 100)
    2nd choice
    i7-640 + gt 330 1gb
    Guys, is it really worthmoney to spend USD 100 to get 1 st choice?
    Both of them still in my budget.
    I want to use it for my simulation and my excel ( lot of data with long iteration). It will be proc intensive. Unfortunately, I dont know my simulation application support for 4 core.
    Please, I need your opinion
    Thanks alot
  2. #2
    Mar 2010
    Toronto, Canada
    Default Re: Help, i7-640m vs i7-820qm
    surprisingly enough, microsoft excel iirc is one of those programs that great benefits from the use of multiple cores so if your excel sheets really are that intensive you'll really see a difference.
    if memory serves the 335 is pretty good bump over the 330 so I'd recommend the 820qm + gt335 as long as your not in dyer need for battery life.
    Dell Precision M6600
    17.3" 1920x1080 Anti-Glare // Intel i7-2860QM // AMD FirePro M8900 // Kingston HyperX 16 GB DDR3 1600Mhz RAM // Samsung 830 256GB SSD // Mushkin Chronos Deluxe 240GB SSD // Seagate Momentus XT 500 GB SSD/HDD // Crucial m4 256GB mSATA SSD
    Sony Vaio SVZ13
    13.1" 1600x900 // intel i5-3210M // intel HD 4000 // 6 GB DDR3 1600MHz RAM // 256GB SSD
  3. #3
    Wisdom listens quietly...
    Aug 2009
    Even if Excel 2007 and above were not multi-threaded,
    [You can configure Excel to use up to 1024 concurrent threads when recalculating, regardless of the number of processors or processor cores on the computer.
    Source:
    Multithreaded Recalculation in Excel
    If you plan on keeping this system for anything over a year $100 will be insignificant to how well it will handle future O/S's and apps.
    Go for the 4 core, 8 thread i7-820 - and, buy an extra battery too - if you need the un-tethered run time.
    Nice system!
  4. #4
    Nov 2010
    Thanks a lot for opinion, so I should buy the 1st choice.
  5. #5
    falling in love..
    Oct 2010
    Browns Mills, NJ
    Quote Originally Posted by tecton View Post
    Yes, for 100 bucks more you are future proofing yourself.
    Alienware M17x R2 (Gaming DTR) : i7-920XM|16GB DDR3|5870 Mobility CrossFire|Samsung 840 Series 512 GB SSD|17.1" RGBLED WUXGA|7HP|Nebula Red
    Sager NP8690 (Backup Gaming DTR): i7-720QM|8 GB DDR3|GeForce 280M|Samsung PM810 series 256 GB SSD|15.6" 1080p LCD|7HP
    Backup server: Pentium G630|8GB DDR3|Gigabyte Z77-DS3H|Intel HD 2000|Samsung 830 64 GB SSD, 2 x Seagate 1.5 TB 5900rpm RAID 1|7HP|NZXT Source 210
    Other Toys: '94 Acura Integra RS|Google/LG Nexus 4 16 GB| Dell Vostro 1500| Looking for an AT&T or unlocked GSM iPhone 4!
  6. #6
    Banned
    Jul 2009
    Say the bells of St. Clement's.
    Yeah. The theory of future-proofing is nonsense. But since you should see a real-world improvement in performance and possibly a longer useful lifespan with what you are using it for, it is money well spent. And if you ever sell it, you would probably make back a lot of the $100 price difference anyway.
  7. #7
    Notebook Virtuoso
    Sep 2010
    $100 is not small or easy money. I don't believe the 820 will give you a noticeable boost in performance. If I were you, I would save the $100 for an eventual RAM upgrade or SSD upgrade.
    Excel uses a lot of RAM for big spreadsheets, and if there is not enough, "paging" will be involved to extend the RAM virtually. Lots of swapping using a mechanical disk drive while the powerful CPU sits waiting is not a very good prospect.
    I see no real advantages, in your case, of the quad-core 820 over the dual-core 640. in fact, even if I went with a 640, I would ask myself very hard why not go with, say, an i5-560.
  8. #8
    Notebook Virtuoso
    Jul 2010
    I agree with Kaso. I personally would be more than satisfied with the 640m and wouldn't pay so much more for the 820qm. That's just me. I don't think you'll notice a difference with excel and if you spent that 100 bucks on a faster hard drive or more RAM and paired it with the 640m you'd really feel it... throughout the entire system.
  9. #9
    Nov 2010
    Quote Originally Posted by Kaso View Post
    Unfortunately, the option just two of them. No processor custom here.
    Quote Originally Posted by Hungry Man View Post
    In my previous post, I mentioned that I will run simulation. For more specific, I run oracle Crystall Ball addin for my ms excel, Schlumberger Petrel and Schlumberger Eclipse. It takes hours to complete.
    Basically, I will buy 1st choice but chek the link below
    Intel Core i7 640M Notebook Processor - Notebookcheck.net Tech
    You'll find that I7 640 m, sometimes mightier in some tests. What about that?
  10. #10
    Judged and found wanting.
    Jul 2009
    Flatland, U.S.A.
    If you mean why the i7-640M is better in some tests than the i7-820QM, it depends on the program being run. Single-threaded programs that stress very few cores will run faster and better on the i7-640M because of the way it's structured/arranged (faster 2 cores). Programs that are well-threaded and better at the utilization of multiple cores will run better on the i7-820QM (4 slower (than the i7-640M) cores).
