Quantcast Clevo M860TU fan replacement
Results 1 to 6 of 6
  1. #1
    Sep 2009
    california
    Default Clevo M860TU fan replacement
    So I my fan in the laptop is dying...sounds like the ball bearing or something is giving as it makes noise while spinning.
    Do you guys know a solution to fix or a replacement fan I can use? I tried to look for replacements but did not find anything and try to find something on the forums as well, any info will help. Thanks
  2. #2
    Little boy forever...
    Dec 2009
    Sydney, Australia
    Default Re: Clevo M860TU fan replacement
    Try WD40
    Metabox P170EM i7-3630QM
    32GB DDR3 PC3-12800 Kingston RAM
    AMD Radeon 7970M 2GB GDDR5 920/1400 72% Gamut Matte FullHD
    Samsung 840 Series 120GB / WD Scorpio Blue 1TB
    2xWD Caviar Green 2TB RAID0 @Welland ME-580J eSATA
    Intel Advanced-N 6235 WiFi
    Chicony 230W PSU
    Windows 7 Pro 64-bit
    Sony Xperia S LT26i
    Asus Nexus 7 16GB
  3. #3
    Feb 2010
    Try to contact with Clevo for a replacement,or simply lubricate the ball bearing.It should work.Wd40 is not proper for this as it does not adhere to metals/plastic and not dense that it will directly got off and spill/spread to all over the place if the ball bearing rotates.
  4. #4
    Jan 2006
  5. #5
    Banned
    Jun 2009
    United Kingdom
    get them from ebay.. it will be fast and quick.
  6. #6
    Infinitely Improbable
    Jul 2007
    Heart of Gold
    Quote Originally Posted by sean473 View Post
    Please show me where you can buy Clevo parts on eBay besides a keyboard...
    NEW! Clevo P157SM Review w/780m
    Sager NP9150 'Prometheus': 15.6" 1080p matte - i7-3740QM - GTX 680m - 16GB 1600 - 512GB+mSATA 256GB Crucial M4 - Blu-Ray
    Sager NP6110 'Firefly': 11.6" 768p matte - i7-3610QM - GT 650m - 8GB 1600 - 500GB Samsung 840
    Sager Reviews: NP6110 w/650m i5 vs i7 | NP9570 w/680m SLI | NP9370 w/ 680m SLI | NP9150 w/680m | PREMA'S CLEVO BIOS | MOD 680m vBIOS
    My WHS 2011 | Trinity A10-4600m 7660G | All my other crap
