Quantcast What are signs and symptoms to when your battery is dead?
Results 1 to 9 of 9
  1. #1
    Sep 2005
    Default What are signs and symptoms to when your battery is dead?
    I have a 2 year old notebook, a Compaq R3000.
    It was functioning perfectly until today...I turned it on but the light which indicates that it is being charged just blinks....I take the bettery out and use only AC power...No blinking..when i put the battery in...blinking...
    So basically it just blinks when i power on...and When the bettery is gone I get no blinking..
    Any idea what it could be? I figure it is probably the battery or even the charger...any suggestions?
  2. #2
    Jan 2006
    Default Re: What are signs and symptoms to when your battery is dead?
    Maybe it mean that the battery is getting old..
  3. #3
    super modfu
    Jan 2005
    Orange County, CA
    blinking usually means charging
    steady means fully charged
    do you have access to an owner's manual?
  4. #4
    Jul 2005
    Outworld
    It doesn't work.
  5. #5
    Jan 2006
    New York
    Well, as one uses a battery, the strength and duration of the charge begins to deteriorate. The more it gets charged the less life it will have. Eventually, the battery will have so little life that you need a new one. Thats the main way that I know my battery is going. (IE 3 hours unplugged --> 1 hour unplugged) etc.
  6. #6
    Feb 2006
    Quote Originally Posted by Androo
    Agreed.
    I had a toshiba satellite a long time ago, and the battery life went from originally 3+ hours to about 10-15 minutes in about 2 years.
    HP Pavilion DV6736nr
    AMD Turion TL-60 2GHz
    3gb RAM
    250gb HD
    NVIDIA 7150M graphics
  7. #7
    Dec 2005
    Well, can you boot your laptop on battery (no AC)? Does it run on battery for an extended amount of time? If you answered no to one or more of these questions, odds are, your battery has died.
  8. #8
    Banned
    Jan 2006
    REAL England
    or the connection between the battery and laptop could be loose/ dodgey
  9. #9
    Senior Member
    Feb 2006
    Inside Your HD!
    Quote Originally Posted by drumfu
    In my compaq notebook "blinking" does not mean charging. rather, it means that the battery is already beginning to drain (low battery) and it's asking to be charged again.
    my compaq has three indicators on the status of battery.
    1. blinking in orange color= low battery status (needs recharging)
    2. steady orange color= the battery is charging
    3. steady light green= battery is fully charged
    Ultraman,
    The problem can be either on your lappy or your battery. If you can, try borrowing the same battery from your friend. if the battery is charging while you plug in ac, then you can be sure that the problem is in your battery and you should consider buying a new battery pack.
    Alienware M17xR3
    Core i7 2720qm | ATI Mobility Radeon 6990M | Hyperx 16GB DDR3 1600mhz | 1920x1080 WLED | Crucial m4 128GB | 320GB HDD 7200RPM | Bigfoot Killer Wireless-N | Win 7 Ultimate
    Gaming Acessories
    Das Pro Keyboard Silent | Logitech G9x | Steelseries Qck Mass Mouse Pad
    Terran Starcraft 2 Player!
    NBR Marketplace Qohelet's Feedback Thread
