Quantcast Laptop LCD monitor shaking/flickering
Results 1 to 8 of 8
  1. #1
    Dec 2009
    Default Laptop LCD monitor shaking/flickering
    Recently my Toshiba u405 laptop monitor has been flickering/shaking as in the screen shakes and stops
    when i move the angle of the monitor it shakes more vigoursly to the point where i can see pink/redish lines across my screen
    whats going on?
  2. #2
    Mar 2008
    United Kingdom - Cambridge
    Default Re: Laptop LCD monitor shaking/flickering
    sounds like the refresh rate isn't set correctly?
    yay..
    Dell inspiron 1720
    17" gloss screen
    320GB HDD
    2GB RAM
    Nvidia GeForce 8600M GT
    2.2GHz Intel Core 2 Duo
    hehe
  3. #3
    Emodicon
    Nov 2008
    Likely, the screen cable is loose or frayed. Open up the laptop and check the hinge area, and make sure the screen cables are securely attached. If it's frayed, then it will need to be replaced.
  4. #4
    Dec 2009
    its nothing to do with replaceing the CCLF though right?
    hmmm opening up the laptop?
    is it hard?
    im afraid i might not get it back together after opening it
    and if its frayed is it expensive to fix?
  5. #5
    Dec 2009
    anyone??????
  6. #6
    Notebook Savant
    Oct 2008
    Chicago
    I don't think your backlight (CCFL) is the problem. It very well could be the connection between the motherboard and the LCD panel.
    I don't know if it's hard or not, I've never opened a Toshiba. You could do a search for the service manual. How old is it? If you're not comfortable doing it AND it's going to void your warranty, then send it in for repair.
    If it's out of warranty, go for it. Being afraid isn't going to fix the problem. At best you fix it, at worse you have to get it repaired.. and if you don't open it, you'll have to get it repaired anyway.
  7. #7
    Banned
    Dec 2009
    CZ
    For first check connector's flex with motherboard and LCD.
    ps now repair 2 asus 1000h , bad connections :-)
  8. #8
    Dec 2009
    its about a 1 1/2 year old laptop
    its the 13" toshibas
    no warrenty as it was bought off someone
    hmmmm i guess i'll open it and give it a look
    hopefully i dont mess anything up
SEO by vBSEO 3.6.1
