Quantcast FN key doesn't work anymore?
Results 1 to 3 of 3
  1. #1
    NBR Reviewer
    Oct 2005
    Irvine, CA
    Default FN key doesn't work anymore?
    It's on a Sony FE. It worked just fine in the beginning and the notebook wasn't subject to any physical abuse. I think maybe I have accidentally pressed some key to turn FN off?
    Is there some key combination that turns it on/off or something?
    Thanks
    Eat more Cheese!!
  2. #2
    NBR Reviewer
    Jan 2005
    Bangkok
    Default Re: FN key doesn't work anymore?
    Try reinstalling/updating the driver.
    "The biggest risk in life, is not taking one"
  3. #3
    Oct 2005
    RI, USA
    There are some suggestions in this thread. Some find it works but I didn't, so I'm still having problem with the FN keys. It might work for you though.
    FN key on Vaio PCG V505 DXP
SEO by vBSEO 3.6.1
