Quantcast control fan speed with registry hack - Page 8
Page 8 of 27 FirstFirst ... 45678910111218 ... LastLast
Results 71 to 80 of 268
Like Tree1Likes
Thread: control fan speed with registry hack
  1. #71
    Notebook Nobel Laureate
    Jun 2009
    Australia
    Default Re: control fan speed with registry hack
    left click on "06040000", then right click on the value "00000000".
    choose "modify binary data".
    Clevo P150HM / Sager NP8150: i7-2630QM OEM (would trade for Q154) | 7970m | 8gb 1600mhz ram | 2x HDD
    Toshiba satellite P750 : B960 2.2Ghz |6gb 1333mhz ram | GT 540M |128gb Samsung SSD + 750gb HDD
    Alienware M17 / OCZ whitebook Arima w840di : SP9400 3.45Ghz (386Mhz FSB) | 9800m GT (dead)
  2. #72
    Banned
    Aug 2009
    i cant export and of course i left clicked so i copied and pasted to the folder
  3. #73
    Jun 2009
    Australia
    I want you to click on "06040000".
    now you should see "00000000".
    do you see that ^^^^^^^?
  4. #74
    Banned
    Aug 2009
    extended hp look like:
    30CB____ extended 30cb:060400000
    under it not you can see in pic
  5. #75
    Banned
    Aug 2009
    yes i see that. it contains 44 53 goes more
  6. #76
    Jun 2009
    Australia
    I want you to right click on the binary value "00000000" in "06040000".
    then choose modify binary data. then using the shift key, highlight all of the data. then right click and copy.
    then click on 00010000, right click on the "00000000" binary value and choose modify binary data. right click and paste!
    please do this
  7. #77
    Banned
    Aug 2009
    here is the thing you want to see
  8. #78
    Jun 2009
    Australia
    good, now:
    please do this
  9. #79
    Banned
    Aug 2009
    i cant highlight all the data the data that is on left remains.is it norma.
    data is to long is it normal
  10. #80
    Banned
    Aug 2009
    done i copied all the data
