Results 1 to 4 of 4
3rd February 2006, 02:33 PM #1Newbie
- Join Date
- Feb 2006
- Posts
- 2
- Rep Power
- 0
Fujitsu laptop hard drive format / fdisk problem
Hello!
I've recently purchased a used Fujitsu B-series laptop. The hard drive is empty, except for a "virtual" MS-Ramdrive partition on it (2MB) created under Windows 98.
I am totally unable to format this drive, even when I took it out and plugged into another laptop (external USB) and yeah ... FDISK says there are no hard drives present.
Anyone knows if this problem can be solved (I've seen multiple RAMDrive help pages but nothing seems to work).
How do I "unlock" the hard drive to make it partitionable and formattable? Even outside of the laptop itself, the drive seems to be "protected" in some way and invisible to many standard HDD tools.
On the laptop, if I boot from floppy into anything other than Windows 98, it does not even see the C hard drive at all!
Should I install Norton System Works or something? I don't want to do a low-level format, either. :-)
Very cryptic.
Thanks.
5th February 2006, 05:00 PM #2Notebook Deity
- Join Date
- Sep 2005
- Location
- Toronto, Ontario
- Posts
- 1,889
- Rep Power
- 26
Re: Fujitsu laptop hard drive format / fdisk problem
Could you give a little more information?
Like were you using the harddrive as your main drive before?
What OS was installed on it, was it the primary boot device, etc etc etc.ASUS Z70Va | 15.4" WSXGA+ | Intel Pentium-M 760 | 1GB DDR2 667Mhz Apacer | 1GB DDR2 Corsair 667MHz | CD-RW/DVD | Western Digital Scorpio WD800VE 80Gb 5400RPM 8Mb Cache
| ATI Mobility Radeon x700 128Mb DDR | Atheros AR5006XS A/B/G~
6th February 2006, 08:01 AM #3
Are you sure you cannot boot from a WindowsXP disk? If it can boot to win98 it will boot to XP if not else then as an upgrade from Win98 itself.
Can you actually enter Win98? If yes, do try Partition Magic."The effect of liberty to individuals is, that they may do what they please; we ought to see what it will please them to do, before we risk congratulations."L2000 LiveStrong
Edmund Burke
6th February 2006, 06:57 PM #4Newbie
- Join Date
- Feb 2006
- Posts
- 2
- Rep Power
- 0
Wow, guys, thanks!
An update - this seems to be a *Fujitsu* problem. The laptop was purchased without any OS (Win 98 boot files, 5 or 6) - that's the catch! The laptop does not have: FDD and CD. I bought an external floppy.
Now, I connected it to my other laptop through USB, partitioned and formatted. Everything is fine, when I put it into Fujitsu, the hard drive "is not partitioned", does not exist. (Note that BIOS perfectly recognizes it). Now I plugged the drive into my desktop, partitioned and made bootable ... Fujitsu says the drive is not partitioned and refuses to work with it.
I inserted ANOTHER hard drive in it - Fujitsu says it's not partitioned (it is formatted and has some files on it!)
It's just that Fujitsu does not recognize ANY drive, which is partitioned with Fdisk and/or outside. Should I use some magic Fujitsu utility to introduce the drive to the laptop?
I know that this model ships with some hidden non-Windows partitions where all installation files are kept, but they are long gone, the drive has been reformatted a few times.
Quite frustrating.
Similar Threads
Fujitsu Siemens Amilo D 1840 Laptop nightmare
By Maskhadov in forum FujitsuReplies: 12Last Post: 31st January 2006, 01:41 PM -
Acer Aspire 2012 WLMi Review (pics, specs)
By Odie in forum Notebook News and ReviewsReplies: 80Last Post: 11th November 2005, 10:41 AM -
Keynamics Laptop Stand Review (pics)
By Skyshade in forum Notebook News and ReviewsReplies: 2Last Post: 18th April 2005, 08:27 PM -
Fujitsu LifeBook S6000 Series Review
By Andrew Baxter in forum Notebook News and ReviewsReplies: 2Last Post: 1st February 2004, 06:50 PM -
New Laptop Hard Drive Technology from Fujitsu
By Andrew Baxter in forum FujitsuReplies: 1Last Post: 6th January 2004, 03:03 PM
LinkBack URL
2013 Alienware Notebooks revealed
11th June 2013, 12:46 PM in Alienware
