*update*
NBR forum member naton has succeeded to get a T9900 (1066Mhz FSB) to run in a notebook with a GL960 chipset, after doing a BSEL mod to force the CPU to run with an 800Mhz FSB.
Details are
here.
Related to this overclock, there are *some* hints that a 1066Mhz series-4 chipset penryn (1066Mhz FSB) cpu could work with a Santa Rosa systemboard. I've put together some info that may help you if you want to try a T9400/T9600 1066Mhz FSB CPU:
1. Pin-compatibility between 1066Mhz and 800Mhz penryns
2. BIOS compatible microcode
If it won't boot, then consider whether new bios microcode is required to support the series-4 penryn CPU. There are tools for various bios and knowledgable on
wimsbios->My CPU isn't recognised,
mydigitallife and
rebelshaven bios modding forums.
There is a suggestion in the
PM965 (800fsb) chipset and a 1066 MHz fsb cpu... thread:
I called intel at 1-916-377-7000 I talked to Tom from Level 5 tech support he assured me that the intel 965m can support the new cpu however GATEWAY and only gateway can make that happen if they provide bios support for the qx9300 mobile quad cpu
[QX9300 is a series-4 1066Mhz FSB quad-core CPU].
3. Clocking the FSB at 1066Mhz on Santa Rosa platform
If the T9400/T9600 boots up, then the mobo will downclock the CPU since the only valid BSEL settings a PM965 chipset has is 133/200Mhz. A PM45 has 200/266Mhz BSEL settings, so it would set it at 200Mhz FSB, BSEL2/1/0 being L/H/L. Can apply methods 0-3 above to increase from 800Mhz to 1066Mhz FSB on a Santa Rosa platform using setfsb and/or pinmods, or both if it's a TME-locked PLL.
 |  | PM45 valid FSB
 PM965 valid FSB |
Left: 1066Mhz-spec FSB CPU's BSEL settings from
Intel C2D 45-nm CPU datasheet. Compare this against the BSEL of 800Mhz-spec FSB CPU's BSEL settings as shown in method 2 above.
Middle: 800Mhz-spec FSB CPU's BSEL pin as highlighted from
Intel C2D CPU's based on 965 express familydatasheet
Right: FSB capability comparison between the PM45 chipset that does support 1066Mhz FSB and the PM965 chipset that doesn't officially support 1066Mhz FSB (max=800Mhz). Anyone trying this mod is in a sense hopeful that the MCHBar functionality still exists if trying the PM45's BSEL selection on a PM965 system.
The potential application here is two fold:
1. to attempt to pinmod a 1066Mhz CPU to function on a Santa Rosa 800Mhz platform. A 1066Mhz CPU has a BSEL signal H/L/H - 200Mhz mode that is the the same as the Santa Rosa 800Mhz FSB platform. So if the CPU was installed, it should theoretically work, so long as the pinouts are compatible.
The idea here being to set acceptable BSEL2/BSEL1/BSEL0 CPU signals so it doesn't apply multiplier locking, whilst sending a different set of BSEL signals to then rest of the system (CPU/PLL/Northbridge) to support a higher FSB operation. How to do this? CPU datasheet advises that BSEL2/1/0 are output pins so suggest:
1. isolate the BSEL1 CPU pin from the circuit.
2. run a logic 1 (3.3V) signal to BSEL1 . Test if this is necessary as it's supposedly an output pin.
3. connect a 0 (GND) signal to PLL FSLb pin. Test if this is necessary as sometimes a disconnect is the same as a 0.
Explanation: (2) makes the CPU believe its running in 200Mhz (800Mhz FSB) mode so it doesn't apply multiplier clamping. (1) then hardwiring the output of BSEL1 logic as seen by any other chips (eg: PLL, northbridge, GM965) to operate in PM45's 266Mhz mode (1066Mhz FSB).
Precedents for success?
PM965 (800fsb) chipset and a 1066 MHz fsb cpu... thread has comments
kaltmond says: T9400 wont´t post in my PM965 nb, confirmed......
Chaz, the moderators closes the thread with Yeah, this thread has reached the end of its usefulness . . read the previous posts. 1066MHz FSBs do not work in the mobile 965 chipset. End of story.
1066 FSB CPU with 800MHz PM965 thread has RickAbraham tell us:
I was talking with a bloke from a local PC repair shop and I watched him fit a T9600 processor into a Dell laptop running the PM965 Santa Rosa platform which is only 800MHz. The processor was fully compatiable which shocked me and I watched the machine boot up after the installation was complete. But what I want to know is are you going to get the full gain using a 1066 FSB when the chipset apparently doesnt support it. I have read on other forums that the PM965 refresh chipset is a freak some claim that it will support 8gb of ram and others claim 6gb of ram. Would the mobo downclock the CPU to 800 FSB or has anyone tested this upgrade and can prove that the chipset will run at 1066MHz ?? I am interested to find out.
Pls report your results.
