Quantcast PLL Pinmod Overclocking Methods and Examples - Page 79
Page 79 of 140 FirstFirst ... 296975767778798081828389129 ... LastLast
Results 781 to 790 of 1394
Like Tree3Likes
Thread: PLL Pinmod Overclocking Methods and Examples
  1. #781
    Dec 2010
    Default Re: PLL Pinmod Overclocking Methods and Examples
  2. #782
    Notebook Nobel Laureate
    Jun 2009
    Australia
    Well looks like TME mode is enabled, you need a pinmod to disable it.
    See the examples in the table on the first page of this thread.
    You have a second problem, you need to find what bit setfsb is changing to cause the system to hang.
    Try changing bit 2 of byte 0 (my guess). Does the system hang when you do that?
    Clevo P150HM / Sager NP8150: i7-2630QM OEM (would trade for Q154) | 7970m | 8gb 1600mhz ram | 2x HDD
    Toshiba satellite P750 : B960 2.2Ghz |6gb 1333mhz ram | GT 540M |128gb Samsung SSD + 750gb HDD
    Alienware M17 / OCZ whitebook Arima w840di : SP9400 3.45Ghz (386Mhz FSB) | 9800m GT (dead)
  3. #783
    Dec 2010
    Quote Originally Posted by moral hazard View Post
    Thanks for the reply, I hope I did it as you told me.
    I changed from PLL Control Reg... upper row 02 which indicated FC and changed the Bin's input to 11111000. Then updated and applied. PLL Control Reg... 02 changed to F8 now.
    But as soon as I hit the set FSB button. Same thing happens. The screen goes black but the hard drive starts reading more than usual, nonstop, until I just hold the power button.
  4. #784
    Jun 2009
    Australia
    No, I wanted you to change the top left byte (value = 03) to 07.
    But it was just a guess. Anyway, if that causes the system to lockup, it might be the problem.
  5. #785
    Dec 2010
    Ok, did that and yes, screen freezes.
  6. #786
    Jun 2009
    Australia
    Well I guess the first step is to do the pinmod.
    Then send an email to abo and ask him to make sure setfsb doesn't change that bit. He will probably want a donation.
  7. #787
    Dec 2010
    Ok, thanks for your time.
  8. #788
    Dec 2010
    Malaysia
    Abo not bothered with any request unless you give 'donation'. Go figure...
    Back on topic, after playing around I get a good stable clock of 2.65GHz (enormous 650MHz overclock) and memory clock of 700MHz (1.4GHz effective). Everything runs great but in games it felt like everything is accelerated, the speeches especially don't have fullstops. I don't mean it sound like chipmunk but the next speeches come before the previous guy finished talking. Any ideas why did this happen? The IDT guy say the other clock (PCI, USB) is independent of the CPU clock so nothing else is overclocked
    ACER ASPIRE 4743ZG
    Intel Pentium P6200 2.13GHz o/c 2.55GHz | 6GB (4GB+2GB) 1066MHz DDR3 | Nvidia GeForce 520M 1GB o/c 925/1850MHz core/shader, 960MHz memory | 320GB Hitachi 5400rpm | Realtek ALC269 with Acer Dolby Advance Audio | LG 14.1" 1366x768 LCD display | Windows 7 Professional x64
  9. #789
    Jun 2009
    Australia
    Not sure about that.
    I read somewhere that when you overclock a PS2 that happens because the timing of the game is linked to the FPS (not sure if this is true).
    I have never heard of it happening on a PC.
    Maybe the windows timer is off, dowload this and check:
    XtremeSystems Forums - View Single Post - ThrottleStop - Performance Adjustment Tool for Core 2 / Core i CPUs
    My friend burebista discovered something interesting when testing with SetFSB. The internal Windows timers that some benchmark programs use can get screwed up when you start overclocking...Here's a testing program I wrote to make sure the timers in your computer are running at the same speed when overclocking. If your internal timers get out of whack, some benchmark programs won't be reliable. The long term timer ratio reported by this program should be 1.0000
    My ratio is 1 so I'm lucky.
  10. #790
    Dec 2010
    Malaysia
    Thanks for the info. Never heard of such problem before. My ratio raises up to 1.3 so that explains it. Don't bother me that much, framerate don't increase much but since its accelerated games feels faster so its a bit advantages in some way
    ACER ASPIRE 4743ZG
