Quantcast PLL Pinmod Overclocking Methods and Examples - Page 19
Page 19 of 140 FirstFirst ... 91516171819202122232969119 ... LastLast
Results 181 to 190 of 1394
Like Tree3Likes
Thread: PLL Pinmod Overclocking Methods and Examples
  1. #181
    Notebook Nobel Laureate
    Jun 2009
    Australia
    Default Re: PLL mod, 200mhz to 266mhz help please
    Clevo P150HM / Sager NP8150: i7-2630QM OEM (would trade for Q154) | 7970m | 8gb 1600mhz ram | 2x HDD
    Toshiba satellite P750 : B960 2.2Ghz |6gb 1333mhz ram | GT 540M |128gb Samsung SSD + 750gb HDD
    Alienware M17 / OCZ whitebook Arima w840di : SP9400 3.45Ghz (386Mhz FSB) | 9800m GT (dead)
  2. #182
    Jun 2009
    Australia
    Look on pages 23-26 of the datasheet.
    Please tell me your default voltage, this is the voltage @10x without RMclock running.
  3. #183
    Sep 2009
    St. Joseph, MI
    Quote Originally Posted by moral hazard View Post
    ok, according to cpu-z, @ 10x it is 1.175
    EDIT:
    it looks like if i set VID3 to 0 i would end up with 1.275 . ??
    looking at the pin layout, i should be able to connect VID3 to the pin directly above it vss.
    i think i'm gunna give it a go...
    Dell 1525 Laptop - PLL Pin modded
  4. #184
    Jun 2009
    Australia
    Quote Originally Posted by FieroGT View Post
    EDIT:
    Sounds right to me.
    I would like naton to confirm it though, because I have never done this mod myself.
    If you do it, could you upload a pic?
  5. #185
    Sep 2009
    St. Joseph, MI
    Sounds right to me.
    ok, yup, i've done it, and its working. i'll take a pic here in a few and post it.
    notes about mod so far:
    1- any apps i've run do not indicate a voltage increase at all. ( they all still show 1.175 )
    2- i know it did raise the voltage because full load temps have gone up considerably
    3- the system is definatly more stable now then it was.
    (i was not able to run at 260mhz for more then 1-2mins, its now been fully loaded at 260 for 10mins error free!)
  6. #186
    Jun 2009
    Australia
    that mod that you just did should get you at least another 200mhz (unless your ram becomes unstable).
    my T7300 is stable @2.6ghz with 1.1625V.
    depending on your ram, maybe you could increase the voltage more and go further?
  7. #187
    Jun 2009
    Australia
    If you change vid4 to 0 instead of vid3 then you will get 1.3750V.
    That should get you very far.
    FYI, my default voltage is 1.2375V.
    EDIT: lol my post count is eleet
  8. #188
    Sep 2009
    St. Joseph, MI
    wow, you think the cpu would take such a higher voltage as that?? (as it is, full load temps went from 70c to 83c) max for this cpu is 100c.
    btw still solid at 260... this definatly made all the difference!
    will attempt to go further in a little bit.
    EDIT:
    heh congrats on the post count!
  9. #189
    Jun 2009
    Australia
    I guess you don't really need it unless you want to try for 3ghz.
    I suggest 266mhz.
    Because if you can get it stable @266mhz then you could do another PLL mod (FSLB pin I think) to change the FSB to be 266mhz.
    So that you wouldn't need to run setfsb.
    Your bootup time will be faster too.
  10. #190
    Sep 2009
    @moral_hazard
    sorry about the length of time it took me to respond. here is the pic of my pll
    RTM875T-606
