Results 1,131 to 1,140 of 1394
12th November 2011, 02:34 AM #1131
Re: PLL Pinmod Overclocking Methods and Examples
SO um, linux....
Latest version of Ubuntu, it seems LMsensors is depreciated and changed to Libsensors3.
None of the tools that were packaged with it have the sames if they still exist at all.
I can't find the i2c module anymore.
Basically it looks like we're screwed. The old way of doing things no longer works.
SoftFSB OCing 4 Linux (Dev)
Any help?
Edit: I'll try the module for grub2Last edited by niffcreature; 12th November 2011 at 02:47 AM.
15th November 2011, 04:17 AM #1132Newbie
- Join Date
- Nov 2011
- Posts
- 9
- Rep Power
- 4
Hello all,
I managed to unlock TME in a HP G7000 mobo (identical to Compaq C700).
The PLL is a SLG8SP512T and comparing the datasheets with SLG8SP513V they look exactly the same but have a different package. So, I tried SetFSB but apart from getting a wrong reading in the divider (I get 3/6 when I should get 3/5), when I try to alter fsb system hangs.. The funny thing is that even if I downclock the same thing happens..
I would go for the FSLx mod but I want to eliminate any chance for SetFSB to work on my PLL first.. any ideas would be very much appreciated.. Thanks in advance!
Note: I have tried all SLG plls in setfsb and get more or less the same results
16th November 2011, 11:26 AM #1133Newbie
- Join Date
- Oct 2011
- Posts
- 1
- Rep Power
- 0
Hi everybody,
I'm trying to overclock the T8100 on my Dell studio 1535 Laptop..
It looks like the PLL (SLG8SP513V) is locked, when I choose it in setFSB that says "PLL Byte error".
After a lot of internet research, PLL pinmod seems to be the only solution for this one, but I don't know wich pinmod I exactly have to do.
Somebody can tell me what exactly I have to do to make the FSB from 200 to 266Mhz?
Dell Studio 1535
ATI mobility HD3450 256
PLL: SLG8SP513V
Chipset: Intel PM965
CPU: T8100 @2.10Ghz
FSB: 200Mhz
Thanks.
19th November 2011, 10:08 AM #1134Notebook Enthusiast
- Join Date
- Nov 2010
- Posts
- 45
- Rep Power
- 7
Update: HP G60 (GL40 + ICH9 + T7500)
Running completely stable with 11.0x Multiplier (1.15v) + 233 mhz FSB + 116.7 mhz PCI-E + 38.9 mhz PCI @ 2567 mhz. Just encoded a 1:30 hr video to H264 at 100% CPU and OS load for 1 hour 10 minutes with no thermal throttling. CPU temp is reading 32 degrees celsius.
19th November 2011, 10:34 AM #1135Newbie
- Join Date
- Nov 2011
- Posts
- 9
- Rep Power
- 4
pabloa2 what is your PLL?
19th November 2011, 01:52 PM #1136Notebook Enthusiast
- Join Date
- Nov 2010
- Posts
- 45
- Rep Power
- 7
30th November 2011, 01:44 PM #1137
Anybody know or asked if sb notebook CPUs are possible to BCLK overclock. Desktop CPUs doesn't OC or OC very little. I am having a 2310M and before upgrading I want to check if it's overclockable.
Thanks in advance.HP Probook 4530s | 1080p | i7 2630QM | 8GB@1333MHz| 320GB & 1TB | Win7 64bit | OSX 10.8.3
eGPU PE3A-R + GTX 460 1GB @ x1.2 opt. 3d06=17765 3dVg=P14602 3d11=p3833 Virtu guide
Google is there for you,..embrace it.
1st December 2011, 08:28 AM #1138Notebook Enthusiast
- Join Date
- Nov 2010
- Posts
- 45
- Rep Power
- 7
8th December 2011, 06:22 PM #1139Notebook Enthusiast
- Join Date
- Dec 2011
- Posts
- 26
- Rep Power
- 4
Hello
Excellent topic, nice lecture, and after 3 day digging into this matter i know what is what BUT i would need someone to guide me by hand :P
i want to pinmod my dell e1705, processor t7400, PLL: ICS954305EKLF. setfsb doesnt read its values.
i was going to spend 100$ on upgrading cpu, but id rather pinmod, i could learn a lot in the process. become my guide to get my appreciation and 50$.
thanksLast edited by krizzz; 8th December 2011 at 08:20 PM.
8th December 2011, 10:42 PM #1140Banned
- Join Date
- Dec 2008
- Location
- YellowBrickRd.AU
- Posts
- 7,931
- Rep Power
- 0
All you need is here Successfully overclocking DV2000 . You'd be increasing the PLL frequency form 166->200 either by setting FSLa (pin41) LOW or FSLc (pin23) HIGH. Setting LOW/HIGH can be done by either isolating the pin and running it to GND/3.3V OR putting a pulldown/pullup resistor in the circuit. If successful then you'd have: T7400-2.16@667 -> 2.60@800
3Likes
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Today, 12:09 AM in Gaming (Software and Graphics Cards)
