Quantcast USB device not recognized!! - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 26
  1. #11
    Apr 2009
    Default Re: USB device not recognized!!
    ok i dragged that usbstor.sys file into my windows folder, what should I do with it now?
  2. #12
    Notebook Virtuoso
    Sep 2007
    Canada
    Go to device manager and use that driver for your "unrecognized" hardware.
    This might make some USB storage device work.
    BTW.. forgot to mention.. have you checked if the hardware IDs of usb devices...etc are valid in device manger?
  3. #13
    Vox Sola
    Mar 2007
    Quote Originally Posted by JSinglez View Post
    One thing I have not done is try to update my system's Bios, mostly because the Acer website is so incredibly unhelpful and full of broken links that I have never been able to locate any information which would help me do this.... I dont know how to and I dont know where to look for a Bios update.
    Updating your bios is a fairly easy process. All you need is the current bios file from the acer euro FTP for the aspire 5100 series. I still have my aspire 5102 and I have talked many acer users through the bios flash process. Follow my post here and you will be okay [note the current Bios version is 3.13 and not 3.05 as it was at the time of that post]. Try the bios flash and see if it fixes your usb problem.
    DELL Vostro 3550
    Intel Core i5-2410M @2.3GHz (Turbo boost 2.9GHz) | ATi Mobility Radeon HD 6630M 1GB | 6GB DDR3-1333| Samsung 830 256GB SSD |
    15.6" LED Display | Wifi b/g/n + Bluetooth 3.0 | Logitech M510 | Zalman NC1000 | Windows 7 Professional x64
  4. #14
    Apr 2009
    Quote Originally Posted by jackluo923 View Post
    sorry for my confusion but how exactly do i select that as the driver for this device? I also do not see anything identified as a hardware ID
  5. #15
    Apr 2009
    Quote Originally Posted by Evolution View Post
    so the readme in the folder for 3.13 said
    BIOS Update from version 3.12 to 3.13 is only possible in DOS Mode
    should I be concerned about that? otherwise i just run the flash exe and it will do everything automatically?
  6. #16
    Vox Sola
    Mar 2007
    What Bios version are you currently on? You can check by using CPU-z.
    DELL Vostro 3550
  7. #17
    Apr 2009
    ahh it says im only on version 2.73
    i suppose I will be fine to just run the exe then! i will do that now and let you know how it goes
  8. #18
    Apr 2009
    ok I have successfully flashed the bios, but my USB ports still do not work
  9. #19
    Apr 2009
    ok turns out im an idiot and didnt notice that there IS in fact already a usbstor.sys in my system 32 folder... :\
    also: every time I try to update the drivers or select that driver for use with the "unknown device" it just tells me that my drivers are up to date for the device.
  10. #20
    Apr 2009
    This is usually a motherboard driver problem, get the latest driver for your motherboard and things should be working well with your USB.
