Results 31 to 34 of 34
Thread: What are average idle cpu temps?
27th September 2008, 11:35 PM #31
Re: What are average idle cpu temps?
Probably - although mine idles at around 35-40 even before UVing.
And speaking of which, I've decided to hold at 1.025V for 11x. It's 0.2V below stock, drops my temps by QUITE a sizable margin (not sure how much though, as my room temp's dropped too), and hasn't caused a thermal trip once through 35 minutes of ORTHOS.
All the other multipliers seem stable too.
I'll give it some 3DMarking and a little bit of TF2, and get back to you.
Heh - it'd be great if I ultimately UV my CPU and OC my GPU (or at least its shaders).
EDIT: Ran a few 3DMark06 runs w/o any CPU problems...it's just that Deep Freeze is running about 3 fps slower for some reason I don't quite know. Going to TF2 now.
EDIT 2: TF2 ran just fine. I think I'm gonna let this thing run ORTHOS for most of tomorrow before I pass official judgment on its stability.Last edited by TehSuigi; 28th September 2008 at 02:01 AM.
Sorry if I'm not around too often - life seems to have gotten in the way of NBR.
Acer Aspire 6920G Lv. 3.1
Core 2 Duo T8300 (1.000V) - GeForce 9500M GS (635/1270/475)- 640GB WD Scorpio Blue
16" 16:9 WXGA LCD - 4GB DDR2-667 - Panasonic UJ-120 - Windows 7 Professional x64
3DMark06 = 4685 (1280x768) | 3852 at stock
Proud Member of the NBR Acer Support Crew - My Crowning Post of Awesome
28th September 2008, 05:55 AM #32
Unvervolting won't affect idle temps.
I idle at 24-26c on my DV9700T and with undervolting I have load temps of 43-45c now. I used to reach 60c before I undervolted.
My 8600GS card idles at 46-48c and load so far is 53c
The main benefit for me is the extra battery life. I have 2 hard drives in my notebook so I lose about 20 minutes of battery life with the extra HD, but gain 30 with undervolting.
28th September 2008, 06:01 AM #33
ALWAYS MAKE A SYSTEM RESTORE POINT BEFORE INSTALLING OR REMOVING ANY SOFTWAREDONT FLASH NEW FIRMWARE WHEN IT FIRST COMES OUT, WAIT TO SEE IF THERE`S ANY PROBLEMS FIRST
Lenovo Ideapad Z580 i5-3210m HD4000 Win7 x64 8gb 1600MHz Samsung 830 256GB SSD Win7 x64
28th September 2008, 06:33 AM #34
LinkBack URL
2013 Alienware Notebooks revealed
11th June 2013, 12:46 PM in Alienware
