Quantcast Intel Wifi Link 5100 vs. 5300; Range or Speed? (More Antennas)
Page 1 of 5 12345 LastLast
Results 1 to 10 of 47
  1. #1
    Mar 2008
    Default Intel Wifi Link 5100 vs. 5300; Range or Speed? (More Antennas)
    I am getting the new Dell E4300.
    Is has the option for the Intel LInk 5300 which has 3x3 Antennas as opposed to 1x2 the 5100 has.
    Does the 5300 offer better range / reliability or merely more speed?
    At least in near future I will probably only us B or G, not N.
    Thanks for the info
  2. #2
    May 2008
    Minneapolis, MN
    Default Re: Intel Wifi Link 5100 vs. 5300; Range or Speed? (More Antennas)
    I've heard the 5100 kind of sucks. Get the 5300.
    Dell XPS M1530: T8300@2.4GHzUndervolted /w Arctic Silver|320GB 5400RPM HDD|4GB DDR2 RAM|8600GT (620/880 overclock)|LED LCD 1440x900|Tuxedo Black|9-Cell Battery
    [most]DEFECTIVE GPU THREADS SUCK!!!
    actually you've got 2 cores at 1.66ghz, which is 3.33ghz....
  3. #3
    Juay de rito?
    Jun 2008
    Panamerican University Mexico
    Get an atheros one, they are a ton times better.
    Alienware M14x | Nebula Red| i7-2630QM | 8GB DDR3 1333 Mhz | 900P WLED | 160 GB Intel G2 SSD | Intel 1000 Wifi | Nvidia 1.5 GB GT 555M | Bluetooth 3.0 | Yes! you get sombreros instead of caps when you buy an alienware here!.
    ORDERED W110ER from LPC Digital Can't wait!
  4. #4
    Banned
    Aug 2008
    intel 5100 worst wirless card ever,
    u dont expect product of such poor quality from intel,
    look at my sig, i had hp dv7t and now gateway p7811, both has 5100 in it,
    drops signal constantly.
    get dell wirless N card.
  5. #5
    Derp
    Aug 2008
    San Diego
    If it helps, I'm using an Intel Wifi Link 5100 only for a week though. I don't know if it's gonna give out on me later, but it's been working well with my Wireless N linksys router. I get 65 Mbps.
    Malibal Lotus P150HM
    15.6" 1920x1080 LED AUO 95% Glossy | i7-2670QM | 8GB DDR3 1333MHz | AMD 6990M 2GB GDDR5 | 128 GB m4 Crucial SSD | 500GB 7200RPM HDD | Intel 6230 | AS5
  6. #6
    Sep 2008
    i got 5100 card in my hp, and i updated the drivers for it on the intel site and i now have wireless N and better reception than my step dads sony. dunno what hes got though.
  7. #7
    Jul 2005
    I have the 5300 in my Lenovo x200, getting speeds of 144 Mbps on wireless N. It hasn't dropped out on me yet.
  8. #8
    Nov 2007
    I upgraded to a 5300. It is fast but I never gave the 5100 a chance, so I have nothing to compare it to.
    Lenovo Ideapad U330- 4gb DDR3, WiFi 5300, Superslim BluRay burner.
    XPS m1330
    Inspiron 1520
  9. #9
    Aug 2008
    All depends on your wireless router, have an Apple Time Capsule Transmitting 5GHZ N only an Intel 4965AGN in my sony TZ and it's connected via the 5GHZ N band at 300mbps, the 2.4ghz N only does 144mbps, anyway i'm getting 5-7MB/s Read/Write speed over 5GHZ N, pretty Impressive, 54mbps G gives only 2-3MB/s, bottle neck is the Hard Drive in Time Capsule which has a crappy SATA-Ethernet bridger chip which max's out at 15Mb/s...
    If I had a better NAS i.e one that does 25MB/s and the wifi link 5300 who knows what speeds I would get...
  10. #10
    NBR Transmogrifier
    Sep 2008
    I have the 5100 card in my Thinkpad x200, and have experienced no problems with it. Range is good, signal is stable, and speed seems good as well(although I have only been able to test with B and G, I don't have a wireless N Router [Yet]). The 5300 might be better in theory, although I have yet to see a single side by side comparison of the two products in real world usage.
