Quantcast Memory Stick Pro - how to insert in memory
Results 1 to 3 of 3
  1. #1
    Jun 2008
    Ireland
    Default Memory Stick Pro - how to insert in memory
    Have a dell Inspiron 1525 notebook with memory card reader, compatible with Memory Stick Pro - but i cannot figure out how to insert the memory stick into the memory card reader - an SD card slots in easily, but how do i to put the Sony stick in - it seems way too small for the slot?
    Bit of a mystery to me i'm afraid - any advice appreciated, thanks!
  2. #2
    D3X
    D3X is offline
    the robo know it all
    Nov 2005
    Toronto, Canada
    Default Re: Memory Stick Pro - how to insert in memory
    Is it a Memory Stick Pro Duo?
    If it's the same as the black memory card, then you will need a memory stick adapter pictured above for it to work in your dell.
    If it's Memory stick Pro, which is the same length as the old blue memory stick. Just stick it in and it should work.
    Apple MacBook Pro Unibody Late 2008 -> Early 2009 DIY Conversion | Core 2 Duo 2.66Ghz ▪ 8GB DDR3 1066 ▪ 9400m + 9600m GT 512mb ▪ OCZ Vertex SSD 250GB ▪ Hitachi 5K500.B 500GB DIY OptiBay ▪ MacBook Air SuperDrive Mod ▪ Snow Leopard + W7 Enterprise
  3. #3
    Jun 2008
    Ireland
    Thanks D3X - yes it is the Pro Duo. Once i saw the photo above, i remembered that i got the adaptor with my camera when i bought it - i had forgotten all about it! Many thanks for your quick response and the photo was really helpful.
Copyright © 2015 vBulletin Solutions, Inc. All rights reserved.
SEO by vBSEO 3.6.1
